Author Topic: Holley efi sniper kit ???  (Read 8768 times)
Offline BradRuiz 83
« on: November 19, 2019, 09:25:15 pm »
think about investing on a efi Holley sniper kit and getting rid of that old carburetor... Has anyone done this if so how has it worked out for you...
Offline Shifty
  • I bleed Bowtie red...
Re: Holley efi sniper kit ???
« Reply #1 on: November 20, 2019, 08:40:46 am »
I have not, but I've been considering a swap from the OEM TBI to a FiTech, and I'm sure in for anyone's opinions as well.
98 C2500 ext cab longbed
Offline Captain Swampy
  • Wisconsin
« Reply #2 on: November 20, 2019, 03:09:17 pm »
Send your worn out TBI to  http://www.rvmorsemachine.com
Offline Shifty
« Reply #3 on: November 20, 2019, 04:04:41 pm »
Thanks Swamp!  :D
Offline 75gmck25
« Reply #4 on: November 21, 2019, 06:49:27 am »
I've been taking a close at the Edelbrock Pro-Flo 4 EFI, and it seems to be a good choice if you want multi-port injection.  It will cost more than the Holley Sniper, but probably not enough to break the bank.
Another challenge you have with EFI is to figure out what to do with your gas tank(s) to keep the system fully supplied with fuel.  A  low mounted electric pump may work fine, but in-tank pump or an external fuel sump would work better.  Some pumps or EFI systems also require a fuel return line, which you might not have on some trucks.
If you install an external sump you can still keep dual tanks and feed the sump from your mechanical pump connected to the tanks.  The sump then has the high pressure pump to feed the EFI.  Edelbrock, FiTech and others sell the external sump/pump systems.
Bruce
Offline BradRuiz 83
« Reply #5 on: November 21, 2019, 07:31:49 am »
Thanks again...
« Reply #6 on: November 21, 2019, 11:15:50 am »
depending on the required pressure you may be able to just install a OEM fuel pump sending unit from one of out trucks with a tbi (86-91).
