Author Topic: ENG OIL PRESSURE  (Read 4937 times)
Offline CashpitC10
ENG OIL PRESSURE
« on: November 20, 2019, 01:48:38 pm »
Have 83c10 with a 305 just changed oil less than a month ago. When i stop at a red light or stop sign the oil pressure drops below 20lbs. What could be the cause of this? Any help would be great.    Thanks Jody
Re: ENG OIL PRESSURE
« Reply #1 on: November 20, 2019, 02:08:06 pm »
Have you checked the oil level?  How many miles on the engine?  What's the oil pressure at 1,500+ RPM?  Was there a sudden decrease in oil pressure at idle or has it been this way for some time?  Have you verified the oil pressure using a manual test gauge or are you relying on the factory dash gauge?
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: November 20, 2019, 04:06:19 pm »
The olde small-block Chevy formula was 10 pounds per 1,000 rpm, if that means anything to ya.
98 C2500 ext cab longbed
Offline bedwards
« Reply #3 on: November 20, 2019, 06:54:49 pm »
If your talking factory gauge, they are notoriously inaccurate.
Offline Shifty
« Reply #4 on: November 21, 2019, 08:33:48 am »
Agreed.  According to mine, I should be pushing the truck instead of driving.  :o
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: November 22, 2019, 01:29:07 pm »
Are you using a multi viscousity oil, like 10-30?
Might be too light for a truck with high mileage.
Could go with a single vis oil, or move up to 20-50.
You don't hear knocking or rattle when that happens do you?
1980 C-10 under construction
