Author Topic: SM465 reverse light switch socket size  (Read 5352 times)
Offline Catrik
« on: December 10, 2019, 02:12:52 pm »
1986 K10 with SM465, wondering what is the socket size for the reverse light switch? I don't have deep socket big enough and nothing else seems to fit there.
Sometimes is takes a second of two for my reverse lights to come on so I'm thinking there's some sludge build up in the switch.
Offline JohnnyPopper
  • Old Goof
Re: SM465 reverse light switch socket size
« Reply #1 on: December 10, 2019, 08:52:01 pm »
Sounds like gunk in the trunk, i.e. corrosion in the sockets.
Just found a incredible product from FLITZ called Metal Pre-Clean. Eats crap off surfaces like I have never seen before!
It is acid based, so you can't leave it on any surface but I tell you what: I have spent countless hours scrubbing off crap when this stuff melts it off in seconds.
1980 C-10 under construction
« Reply #2 on: December 10, 2019, 09:37:30 pm »
Flitz products seem to have fairly comprehensive applications...
https://www.youtube.com/watch?v=_KWxjShHl4E
Thanks.
Offline vze2x5pt
« Reply #3 on: December 12, 2019, 06:17:57 pm »
To answer the original question mine is the original Pollak 2 blade style and it takes a 7/8" deep socket to remove it. there is a gasket around it that may not come with a new switch.
Offline Catrik
« Reply #4 on: January 21, 2020, 02:52:34 pm »
Thanks! I somehow missed your message earlier. I used a 23mm socket so 7/8" is probably the correct size. Turned out that a deep socket was too tall to fit in there with a ratched so I ended up having to make a custom socket from a cut off box end of a spanner, piece of pipe and a nut in the other end so I could turn it with another spanner.
I opened up the old switch and it was burned up from the contact points. If anyone else has this issue then you could try turning the plastic connector part just a few degrees so the contact points change. It might fix it, or it might snap off and now you have a broken AND oil leaking switch...  ;D
Oh and good call with the gasket. I would have left mine sitting of top of the transmission if you didn't mention it.
  • Old Goof
« Reply #5 on: January 21, 2020, 03:46:01 pm »
I like it! Going old school............."if you don't have one, make one!!"
