Author Topic: Wheel and tire size  (Read 6113 times)
Offline bigblockchevelleman
Wheel and tire size
« on: December 31, 2019, 08:35:54 pm »
Wanting to find wheel and tire compnation that won't stick out pass the body on 87 on the rear the truck will only be a fun toy THANKS
Offline JohnnyPopper
  • Old Goof
Re: Wheel and tire size
« Reply #1 on: January 01, 2020, 06:56:29 pm »
Start by doing some measurements.
You have a center line of reference- the surface where your existing wheel rides on the axle. Call it the prime meridian...
Start by measuring that point to the inner fender surface.
Then from the same surface to just inside the outer fender.
Add those two to get the overall distance from just inside the outer fender to the inner fender surface.
You'll have what you need to get guidance from and wheel and tire pro.
1980 C-10 under construction
« Reply #2 on: January 03, 2020, 04:03:13 pm »
Thank you
