Author Topic: Wire gauge size?  (Read 6217 times)
Offline bake315
Wire gauge size?
« on: January 11, 2020, 08:34:22 am »
Howdy folks.
So I found and bought myself yet another truck (this really is a disease), this time a ‘79 K10.  Anyway, I’ve been going through the hatchet job that is the current state of its wiring, and I am going to need to rebuild some of the wiring harnesses. I want to buy correctly matched SXL wiring for each part that needs fixing, and I want to make sure that I get the gauges correct.  The engine harness running up from the starter was pretty badly butchered. Can anyone tell me the gauge size of each of these wires? I have to restore the fusible links (missing) also.
I know I could always buy a new one for that section ready-made, but $200 just seems a little steep.
As always, I appreciate the help!
bake315
« Last Edit: January 11, 2020, 08:37:01 am by bake315 »
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Re: Wire gauge size?
« Reply #1 on: January 11, 2020, 09:34:55 am »
1979 Wiring Manual
Wire callout code is wire size in (mm)2 wire color - circuit number (insulation type).  So, 3 PPL-6 (SXL) on the diagram is the 3 (mm)2 purple wire, circuit #6, using SXL insulation.  A metric to AWG wire size conversion table is on page 1; the starter wiring diagram is on page 7.
  • Starter solenoid wire (ckt 6) is 12-ga purple
  • B+ feed to the firewall junction block (ckt 2B) is 10-ga red
    • Ckt 2B is protected by a 6" long, 14-ga fusible link at its starter B+ connection
  • B+ charge lead from the alternator (ckt 2G) is 12-ga red
    B+ feed to the firewall bulkhead connector (ckt 2J) is 12-ga red
    • Ckts 2G & 2J share a single 6" long, 16-ga fusible link at their starter B+ connection
  • the battery cable is 2-gauge
Be sure to use high-temperature loom to encase the wires as they route up along the back of the motor.
Offline bake315
« Reply #2 on: January 11, 2020, 09:58:55 am »
Thanks so much, Rich.  Exactly what I needed and more.  Breaking down the codes and conversions really helps a bunch!
bake315
