Author Topic: 1991 Suburban Instrument Cluster  (Read 10444 times)
Offline Deercreekfarm
« on: February 01, 2020, 08:43:06 pm »
So the restore is still progressing, slowly but it’s progressing!
Now I’m working on the instrument cluster. The oil pressure gauge doesn’t work along with the odometer mileage and trip meter. Other than that everything else works good (speedometer, coolant temperature, fuel gauge).
I found a replacement cluster for a diesel that is ALMOST identical with just a few differences (mine has low coolant light in bottom left, the one I found has it under the speedometer/trip meter knob) Now the replacement one also has what appears to be the same blacked out lower left gauge where mine has the low coolant light. The ONLY other difference I’ve seen is mine says Quartz under the odometer/trip meter on it and the replacement doesn’t.
My question would be, before I spend the money, Will this work in my dash? I don’t know much about these things but I thought I read somewhere that if the cluster says quartz that the replacement has to say quartz also or it won’t work. Can anyone shed some light on this for me?
Thanks for the feedback!
« Last Edit: February 02, 2020, 07:14:22 am by Deercreekfarm »
Re: 1991 Suburban Instrument Cluster
« Reply #1 on: February 02, 2020, 07:13:00 am »
So after looking at different year model clusters I see some have a clock in the lower left where mine has the blacked out gauge that lights up to say low coolant. These clocks also say quartz.
My cluster does not have a clock but says quartz under the odometer/trip meter. I’m guessing this just means quartz movement for the odometer/trip meter maybe?
« Reply #2 on: February 02, 2020, 07:32:02 am »
Clocks were an option and all says Quartz.  When the speedometer says quartz it is electronic as opposed to the older cable driven
« Reply #3 on: February 02, 2020, 08:17:23 am »
Zieg85,
Thanks for clarifying that for me so I will need a cluster that reads quartz on the speedometer. I do have a 4L80e so that would make sense. Can you replace just the speedometer/odometer gauge or do you have to replace the entire cluster?
« Reply #4 on: February 02, 2020, 12:23:58 pm »
its a completely different backing (cluster housing) you can find adapters to go from the electric signal to cable but its not going to be cheap.
« Reply #5 on: February 03, 2020, 09:51:23 pm »
Thanks for the insight. I did find one with the electric speedo out of a 91 suburban so I snatched it up.
Offline ehjorten
« Reply #6 on: March 25, 2020, 08:55:22 am »
My 1991 V3500 had the speedometer with a trip meter that was messed up.  I just removed the speedometer and sent it out to have it repaired.  Can't remember what I paid, but I don't think it was too bad!
-Erik-
