Author Topic: Th350 L2 L1  (Read 4422 times)
Offline zacksmith03
Th350 L2 L1
« on: February 06, 2020, 09:51:41 pm »
Please bear with me as this is my first post on here. I have a 1975 k10 with a th350. I haven't had it very long, and I want to know if all th350s have an L2 and an L1. There only seems to be one shift underneath drive, but the shifter plate indicator thing says it has L2 and L1. I'm stumped.
Re: Th350 L2 L1
« Reply #1 on: February 06, 2020, 10:05:30 pm »
You should distinctly feel 5 clicks from Park to 1st.  If you don't your linkage is out of adjustment or you have something bent or a sagging cab due to rust.  Welcome from the St. Louis, MO area
Offline zacksmith03
Re: Th350 L2 L1
« Reply #2 on: February 06, 2020, 10:40:41 pm »
Thanks, I recently went through the entire truck, taking everything apart down to the frame and rebuilding it. I did tighten the linkage once I reinstalled it, but maybe I didnt tighten it enough. I assume it needs to be as tight as possible?
