Author Topic: LS swap Gurus  (Read 75274 times)
Offline jon316
Re: LS swap Gurus
« Reply #30 on: June 19, 2020, 07:00:43 pm »
Ok I’ll check them! Thanks! I’ll be doing some nice wilwood and new rotors so I’ll make sure they’re working properly.
Offline jon316
Re: LS swap Gurus
« Reply #31 on: June 20, 2020, 09:15:55 am »
So I got this D52 Wilwood kit specifically for the c10....and also a set of rotors. First the rotors are too big, not even the bearings fit. So I said screw it need the truck to run already I’ll run the current rotors for now. And now the brake line bolt doesn’t match! What a mission. Any help?
I’m about to just put everything back and rebuild that one caliper. Never dealt with so much issues on a truck. But I’ve worked on mostly OBS trucks and NBS trucks.
Offline jon316
Re: LS swap Gurus
« Reply #32 on: June 20, 2020, 09:30:02 am »
I’m seeing jb1 and jb3 and jb5.... I have j50? Not sure what rotors and calipers I should use!
Re: LS swap Gurus
« Reply #33 on: June 20, 2020, 04:45:50 pm »
Based on the VIN and J50 vacuum power brake code your truck was constructed with JB3 brakes.
Brake Tech, what do all the numbers mean..
Offline jon316
Re: LS swap Gurus
« Reply #34 on: June 20, 2020, 05:03:25 pm »
Got it, went to oreillys and stuck with the oem stuck. Matched the best to jb1/jb3 so that’s what I went with and worked out. Thanks!!
Offline 87ChevyR10
Re: LS swap Gurus
« Reply #35 on: September 07, 2022, 01:06:47 pm »
Holy sh^*! See? Reading posts where others are having issues lets you know that what you might have going on could be child's play to someone else's troubles. When I rewired my fuel system's wiring I found a mystery green wire wired into the factory wiring for the fuel pump as well as a cut wire grounded to the frame. I thought my situation was ugly.
dang man. Hope you got all that sorted out!
