Author Topic: I could use some help with an engine decode.  (Read 5477 times)
Offline DanMcG
« on: March 12, 2020, 11:47:13 am »
I just picked up a 400 ci 3951509 basket case and I'm have a problem decoding the numbers on the right front of the block.
The numbers are F0317T space S
and T77518541  Is the T77 for truck and the rest the vin number?
Can anyone help me out here? Thanks
« Last Edit: March 12, 2020, 11:50:44 am by DanMcG »
Re: I could use some help with an engine decode.
« Reply #1 on: March 12, 2020, 12:31:51 pm »
Here is 2 possibilities...TLS   1977   400   conv.cab                   R LF4   175   4   K-10 to 2500
                                 TLS   1979   400   con. cab, a/t, Cal   R LF4   170   4   K-10 to 2500
« Reply #2 on: March 12, 2020, 12:33:45 pm »
Those are the only 2 I could find looking for engine code T_S and 400 CID
Offline DanMcG
« Reply #3 on: March 12, 2020, 12:56:48 pm »
Thanks zieg85 , but it's a 2 bolt main.
Edit: or does the"4" you listed stand for four barrel?
« Last Edit: March 12, 2020, 01:09:34 pm by DanMcG »
« Reply #4 on: March 12, 2020, 02:45:03 pm »
4bbl carbination
Offline DanMcG
« Reply #5 on: March 13, 2020, 05:15:39 am »
Can anyone explain the T77.... number? I'm been searching the net and it doesn't make sense to me. It has 9 digits and everything I read about has 8.
Offline Poppy 87
« Reply #6 on: March 14, 2020, 07:07:59 pm »
Could one of those character be a "Z" instead of a 7?
Sent from my XT1254 using Tapatalk
Offline MIKE S
  • Member
« Reply #7 on: March 14, 2020, 07:53:28 pm »
I think T is for Tonawanda engine plant
Offline DanMcG
« Reply #8 on: March 15, 2020, 11:02:41 am »
So what I have been told is that if the second 7 is a Z then it would be K= GMC, 7=1977 and Z =Fremont Ca plant.
And as far as it being a 77 or 79, the casting date is October 18, 76 so 77 would have to be the build date.
Thanks for the input everyone!
« Last Edit: March 15, 2020, 11:05:44 am by DanMcG »
Offline Poppy 87
« Reply #9 on: March 15, 2020, 12:39:40 pm »
Glad to see that you found it!
Offline JohnnyPopper
  • Old Goof
« Reply #10 on: March 15, 2020, 03:11:13 pm »
Just a question: why is the ancestry of motor parts important?
I mean, is there a quest to make a project 'correct'?
My question is not to knock anyone who might be a purist, I just haven't noticed this as a trend.
Now if you're talking VW, those purists are in a rare stratus, just ask them!
1980 C-10 under construction
