Author Topic: 454 block and crank questions  (Read 5624 times)
Offline tlynde
« on: October 17, 2006, 05:52:00 pm »
hey all,
I tore down that 454 I got for free and have a few questions. I'ts a 2 bolt main will that handle the 500 ponies and 500 # of Torque that I hope to achieve, and will a cast crank handle that or will I need to upgrade to steel.
I will not be towing anything or racing, it is going in my 83 half ton 4x4 and the 383 is coming out.  (yep, Mo power);)
thanks guy's
T
Offline roundedline
Re: 454 block and crank questions
« Reply #1 on: October 17, 2006, 05:04:00 pm »
It can handle it just fine.  I ran the mess out of mine for 8 years that way, it is still together.  If it is going to be a street/driver car, it will be ok.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline tlynde
« Reply #2 on: October 17, 2006, 07:24:00 pm »
thanks roundline,
It's not exactly a daily driver, I'm building it for running up in the hills and sloggin' through the mud, but nothing too extreme I'm too old for that nonsense.
do you have a suggestion on head, cam profiles I'm shooting for 9.5-1 to 10.-1 comp. so I can still burn pump gas but enough comp. to get the power I want.
It looks like it's cheaper to go with a 119cc combustion chamber and use dome pistons to up the comp. will there be a problem with that scenario. I've never used dome's before and I'm a little leary.
thanks again.
T
Edited by: tlynde at: 10/18/06 8:20 am
Offline roundedline
« Reply #3 on: October 18, 2006, 05:05:00 pm »
I wouldn't run dome pistons on a 454, in fact you don't need but about 9:1.  You can make 500hp out of a flattop piston in a 454 with 119cc heads, and still run on pump gas.
I found this for comparison:
www.hotrod.com/techarticl...ndex5.html
Plus some crate motors with gobs of power.
www.gmgoodwrench.com/GMPe...p?engine=3
For a good package with all matching Parts Edelbrock has some good ones:
www.edelbrock.com/automot...e_5500.pdf
Project Su
Jimmy 2WD Project
Offline tlynde
« Reply #4 on: October 19, 2006, 07:54:00 am »
thanks for the info that is a great article.
T
