Author Topic: 81 K10 Build  (Read 384186 times)
Offline Shifty
  • I bleed Bowtie red...
Re: 81 K10 Build
« Reply #150 on: March 09, 2021, 08:30:57 am »
 8)
98 C2500 ext cab longbed
Offline Mike81K10
Re: 81 K10 Build
« Reply #151 on: March 14, 2021, 08:48:25 pm »
Got my kick panels installed, Hood Release, Ground Bar, Hood Hinges with the Rubber pad (did not have one previously and had to modify some to work), and neutral safety switch installed (among a few other things). Have a Dk Blue and Green wire two pin connector that goes through the firewall via a grommet (next to the fuse box) that I am not sure how it will connect yet. According to the wiring diagram, it looks like the neutral safety switch. Will take information on it or pictures from your truck with it connected. Only have the one big hole to fill in behind the engine and a couple of firewall pad retainers to install along with the steering column, besides completing the harness install. Then hood, fenders, and complete the rest of the A/C install.
« Last Edit: March 14, 2021, 08:51:48 pm by Mike81K10 »
Offline Shifty
Re: 81 K10 Build
« Reply #152 on: March 15, 2021, 09:39:17 am »
If all else fails, you could lop the ends off, and install male and female GM Weatherpak connectors as used on later model vehicles, though that's not the "correct" way to do it.
Re: 81 K10 Build
« Reply #153 on: March 15, 2021, 09:53:54 am »
The safety start circuit is yellow and purple.  Dark blue and light green are for backup lamps.
Offline Mike81K10
Re: 81 K10 Build
« Reply #154 on: March 16, 2021, 04:00:37 pm »
Reworked my wire harness by replacing some of the wires and I cleaned it up a bit (still needs more cleaning and bought some contact cleaner yesterday). However, the labels on it were in bad shape and what was left disappeared when I tried to clean off the dirt and grime. It bothered me a great deal and so I bought some fine tip paint markers and relabeled the fuse block by hand. Would love to get OEM labels that would stick on and thought about a new harness, just did not think it was worth the money (> $500.00) since mine is in good condition.
Offline Mike81K10
Re: 81 K10 Build
« Reply #155 on: March 18, 2021, 06:17:44 pm »
In between the nasty storms, I installed my Cowl and Windshield Washer Hoses and nozzles. Saved me much trouble finding the pins for the cowl at the local salvage yard. Took care of a few minor things as well. More difficult and takes longer to put the truck back together than it was to tear it apart.
I'm cleaning up and getting ready to install the distributor harness and it has a wire for what looks like it goes to a detonation sensor that has not been used many years. The connector for the detonation sensor is gone and I do not have a detonation sensor on my engine. Was wondering if anyone uses a detonation sensor on their truck.
« Last Edit: March 19, 2021, 02:15:24 pm by Mike81K10 »
Offline Shifty
Re: 81 K10 Build
« Reply #156 on: March 19, 2021, 09:36:10 am »
Hummin' along Mike!
Offline Mike81K10
Re: 81 K10 Build
« Reply #157 on: April 04, 2021, 09:13:00 pm »
Got many small things done today. Working on my wire harness and should be finished with it in 2-3 days. I installed the ESC Controller today, the rest of my firewall pad fasteners (had to find some that would work at the local parts store), those that came with it would not work, installed my hood latch, and refinished my clutch push rod, and worked on the linkage a bit by installing an insert to prevent wear. However, I am having to slowly sand the inside until the clutch pushrod fits into it. Figured I would attach just a few pics from today. I thought about doing away with the ESC Controller and getting an MSD Distributor. Not sure if I should keep stay original or go that way and close off the firewall hole for the wires from the ESC and pull out the controller yet. Any suggestions!
Edit: Went ahead and pulled the ESC back out and may weld in a patch panel where the ESC wire harness comes through the firewall, unless I use it for a CD Ignition Box under the dash. Wish I had thought of it prior to refinishing the firewall, but it is what it is.
« Last Edit: April 06, 2021, 09:49:08 pm by Mike81K10 »
Offline Mike81K10
Re: 81 K10 Build
« Reply #158 on: April 07, 2021, 05:10:53 pm »
Pulled the trigger and ordered the MSD 8362 From Holley. Installed a bushing in my clutch peddle pushrod mounting hole to prevent ware and looseness. Have to get another boot and then will get my linkage reconnected. Should complete my wiring by the end of this weekend and then I have to do a little work on my hood get it installed and then on to my fenders & wheel wells.
Re: 81 K10 Build
« Reply #159 on: April 08, 2021, 04:21:40 am »
Did you land your brake differential pressure switch connector there intentionally?
Offline Mike81K10
Re: 81 K10 Build
« Reply #160 on: April 08, 2021, 08:51:42 am »
Put the switch back on the clutch peddle into its original location and the electrical connector for the proportioning valve. Any suggestions of something better will be gladly accepted.
« Last Edit: April 08, 2021, 08:54:57 am by Mike81K10 »
Re: 81 K10 Build
« Reply #161 on: April 09, 2021, 02:39:31 pm »
Like this
Offline Mike81K10
Re: 81 K10 Build
« Reply #162 on: April 09, 2021, 10:55:34 pm »
Thanks VZ! Mine must have got bent down and I did not know it. Will bent it back up. Been working on my harness some more today and have it about right. I Have a grey and yellow wire that goes to the (appears to be radio connector) know what the radio connector looks like just not sure if there is a connector prior to it, where these wires go. Will try to track down the other wires to find it tomorrow and the radio wire harness. Will attach a pic (see the Yellow and Grey) the two wires broke off and not contacted to anything. Wiring on the truck is a pain (but getting use to it and not as bad as it was at first) and I was a master aircraft electrician. Problem is the location of some connectors and 4 or wire spliced junctions that has no location and the diagrams in my maintenance book it not the best of quality (hard to read when two diagrams bleed together). I am used to well written and clear schedmatic diagrams. Will use weather pack connectors in places when I am done.
I also have the switch on the transfer case that I have to try and hook up. I installed a new one and a weather pack pig tail to the switch, need to wire it in with no existing wires. I believe the old switch was probably wired up at one time and disconnected and the wires disappeared from someone doing transmission work or such. Now days, I do almost all work on my truck. Will still have to wire in the Vintage Air GenIV unit when I get to that point.
« Last Edit: April 09, 2021, 11:42:44 pm by Mike81K10 »
Re: 81 K10 Build
« Reply #163 on: April 10, 2021, 01:00:03 am »
Yellow is accessory power, gray is instrument panel dimmer.
Offline Mike81K10
Re: 81 K10 Build
« Reply #164 on: April 10, 2021, 03:57:21 pm »
Thanks bd! My truck is getting a bit dusty from the bad weather and needs cleaning.
« Last Edit: April 10, 2021, 06:46:23 pm by Mike81K10 »
