Author Topic: 81 K10 Build  (Read 384213 times)
Offline Shifty
  • I bleed Bowtie red...
Re: 81 K10 Build
« Reply #240 on: April 04, 2022, 09:06:29 am »
Looks really good!
98 C2500 ext cab longbed
Offline 1980K20
Re: 81 K10 Build
« Reply #241 on: April 05, 2022, 09:02:38 pm »
Nice work!
1952 International L112 - waiting for EV conversion
1967 Camaro - 250 six cyl, 200-4R
1980 K20 4x4 Fleetside - 350 SBC roller Cam, TH350
Offline Mike81K10
Re: 81 K10 Build
« Reply #242 on: April 09, 2022, 08:05:43 pm »
Pulled my dash pad back out and refreshed it with some new color (same color just new coats). Then I completed the cluster, bezel, and the trim that goes on the door threshold. Before I started the rebuild I had an after market aluminum and went back to the black plastic OEM style. Some time ago I had my shifter knob stolen and when I could not find the OEM replacement, I ordered a custom made knob with the shifter pattern engraved on it. It is basically an engraved pool ball. I installed a battery tender (Charger/Maintainer).
Offline JohnnyPopper
  • Old Goof
Re: 81 K10 Build
« Reply #243 on: April 10, 2022, 01:21:30 pm »
Nice work man, she is really looking good.
Same color as my K10 I believe.
Paint that seat belt box... ;D
1980 C-10 under construction
Offline Mike81K10
Re: 81 K10 Build
« Reply #244 on: April 10, 2022, 02:23:35 pm »
Thanks, I have to get my horn fixed and a few other things. However, it is very close to driving again.
Offline 1980K20
Re: 81 K10 Build
« Reply #245 on: April 10, 2022, 09:33:11 pm »
Looks great!
Offline Mike81K10
Re: 81 K10 Build
« Reply #246 on: April 13, 2022, 03:34:48 pm »
Thanks! Ran into a problem that was a little strange and an easy fix.
 Symptoms: Marker lights on front fender would not work at all, both turn signal indicators on gauge cluster stay lite (solid - no flashing), front running lights/turn signals that are located in front bumper stay on when headlights turned on (OK), front running lights/turn signals both flashed when one was turned on.
 Solution/Fix: Remove the 1156 light bulbs and install 1157 light bulbs. Was relieved my wiring was not the problem because I did replace wires and sockets in the harness. Having the wrong bulb installed can cause many problems.
Offline Mike81K10
Re: 81 K10 Build
« Reply #247 on: April 25, 2022, 03:01:09 pm »
Been looking for a good salvage yard bumper without luck. My bumper is an 81-82 only! My original OEM bumper that came with my truck was painted white and my rear bumper was painted a Navy grey. My trucks original color was a light (baby) blue. I got a front chrome bumper some time ago from a salvage yard but it has a few small rust spots that I can get rid of with steel wool, but they come back later. So I decided to go ahead and repaint my bumper to match my paint and also refinished the supports/brackets to mount it. Perhaps later I will get a chrome one.
Offline Shifty
Re: 81 K10 Build
« Reply #248 on: April 25, 2022, 04:30:26 pm »
I'd like to see that on the truck!  8)
Offline Mike81K10
Re: 81 K10 Build
« Reply #249 on: April 25, 2022, 06:24:26 pm »
I have rain for a couple of days. Should put it on the truck Wednesday or Thursday.
Re: 81 K10 Build
« Reply #250 on: April 25, 2022, 06:48:02 pm »
Looks like it came out nice!
Offline Shifty
Re: 81 K10 Build
« Reply #251 on: April 26, 2022, 09:08:05 am »
What's "rain"?
Offline Mike81K10
Re: 81 K10 Build
« Reply #252 on: April 28, 2022, 08:59:50 pm »
Installed my front bumper. At first had some problems getting it lined up for all the bolts. Still have to install the wind deflector on the bottom, but that is no big deal. I have to spend a little time on another truck to make some repairs prior to getting back on my 81 K10.
Offline 1980K20
Re: 81 K10 Build
« Reply #253 on: April 28, 2022, 10:04:53 pm »
Very nice looking!
Offline Shifty
Re: 81 K10 Build
« Reply #254 on: April 29, 2022, 08:55:45 am »
Unique and looking sharp!  8)
