Author Topic: confused on head numbers  (Read 5022 times)
Offline newowner1
« on: October 19, 2006, 08:42:00 pm »
I have 2 sets of heads. One is 3932411 and I believe mortec said 1.94 ,1.50 76cc. The other set is what im confused on. they are 462624 I am finding very conflicting answers, I had these on a fully rebuilt motor that ran for about 1 minute but then could not figure out why it quit running. Maybe this is why. that casting number is said to be a 305 and 350 casting number. the 305 valves are 1.94,1.50 76cc and the 350 valves are 2.02, 1.60 76cc. How am I able to tell which set I have. And if they are the 305's would that have caused my 350 to not run? I am looking for new heads for my truck and although these are not the best, it is what is available to me. Thanks for any help.
Offline roundedline
Re: confused on head numbers
« Reply #1 on: October 20, 2006, 12:54:00 pm »
462624 is 79-85 350 heads with 1.94 int and 1.5 exh.
There isn't a 2.02 version of these heads.
The closest number I have for 3932411 is 3932441 which are one of the generaly considered "good" heads.  They are the 69-72 327/350 heads with 1.94 int and 1.5 exh.
Neither should cause the motor not to run.  Technically you can bolt any head (short of a ones that came off a 400 - steam holes) on a SBC from 1955 to 1996 (keeping the associated intakes) and it will work with no problems.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
