Author Topic: Steering column swap help  (Read 6424 times)
Offline dieselman123
  • professional
« on: April 11, 2020, 02:32:45 pm »
Hey guys i have a 83 c10 Silverado trim swb
 I recently purchased a steering column from a 85 blazer that was in better shape then mines. I like it because i woud like to move the dimmer switch and wiper switch in column due to i can't get my pulse to operate. My question is upon doing the swap i noticed that the shaft in the 85 is different. I have the splined shaft and the 85 is the d shaped shaft. Is there a way i  could use the steering column on my 83. What needs to be changed
Gotta clean my back windshield cause I'm too busy kicking up dust
Re: Steering column swap help
« Reply #1 on: April 11, 2020, 06:02:42 pm »
Splined shaft was 73-77 so you have a different one.  From 83-86 it is pretty easy especially if the pigtail plugs were left with the 86 column
  • professional
« Reply #2 on: April 11, 2020, 06:22:48 pm »
The column out my truck was splined so wat do i need to do to use the one from the 85???? Change the steering shaft coupler where the splined shaft goes into??
« Last Edit: April 11, 2020, 06:47:21 pm by dieselman123 »
« Reply #3 on: April 12, 2020, 10:23:36 am »
You just have to get the intermediate shaft from the newer style
