Author Topic: SBC 350 Hydraulic Valve Lash Adjustment  (Read 10059 times)
Offline cosmic_3000
« on: April 22, 2020, 03:25:22 pm »
Hello all,
I recently removed the heads on my 350, and during reassembly it was time for the valve lash adjustment. Just to note I didn't remove the lifters, they stayed in their bore, I just pulled the pushrods out. Engine hasn't ran in about 2 months.
Now during reinstall, I adjusted it this method:
- Turn engine #1 TDC, and adjust intake valves 1, 2, 5, 7, and exhaust valves 1, 3, 4, 8.
- Turn engine 360 degrees to #6 TDC, and adjust intake valves 3, 4, 6, 8, and exhaust valves 2, 5, 6, 7.
- For adjustment, I tightened until there was no vertical movement in the pushrod, then 1/2 turn more.
I thought that was everything that needed to be done, no? The pushrods were tight when I finished, but the next morning I went out and check, and I could turn them by hand again.
I'm not sure if my valves need more adjusting.
Thanks for your help!
Offline JohnnyPopper
  • Old Goof
Re: SBC 350 Hydraulic Valve Lash Adjustment
« Reply #1 on: April 22, 2020, 04:02:01 pm »
You mean you could turn the push rods by hand, right?
Not unusual, your lifters have some wear, so they won't have the spring they had when new.
All they need is a supply of oil/ pressure and they will tighten up just fine.
However, I always though it was 3/4 turn after zero lash? Someone will school us if needed.   ::)
1980 C-10 under construction
Offline FlatBlack77
« Reply #2 on: April 22, 2020, 07:00:56 pm »
I am pretty sure myself about the 3/4 of a turn past zero lash.
I always do the final adjustment with the engine running. But I am most definitely not looking to start an argument about it.
Offline 75gmck25
« Reply #3 on: April 22, 2020, 07:12:10 pm »
I've always jiggled the pushrod up and down to check clearance.   If you try to "feel" clearance by turning a rod that is well lubricted with oil it is much harder to estimate the zero clearance point.
 Its easier to get a consistent "feel" by jiggling it up and down to find the zero clearance point where you can't feel it move.  Then add the preload of  about 1/2 turn.
Bruce
« Reply #4 on: April 22, 2020, 08:54:43 pm »
The method you described works fine for a stock-to-near-stock camshaft profile.  Regarding the zero-lash hydraulic lifter preload adjustment, anywhere in the range of 1/2 to 1 full turn is suitable.  The key is consistency in the preload from valve-to-valve; adjust all valves exactly the same.
FYI - In some high-performance applications, a smattering of builders recommend zero lash, zero preload to eliminate the possibility of lifter pump-up in the case of valve float.  But, that sort of defeats the purpose of hydraulic lifters, and I don't condone the method.  It is far better to employ the proper spring and retainer combination to match the cam's profile, the valvetrain mass, and the engine's purpose, being mindful to limit engine RPM to a safe level.
Regarding the "apparent loss of lifter preload" based on the ease of rotating some of the pushrods after the engine sets overnight without running, hydraulic lifters naturally bleed down under valve spring pressure given a sufficient amount of time.  The greater the accumulated wear between the lifter piston and its bore, the quicker that bleed-down occurs.  As long as a lifter is low on the camshaft lobe ramp when the engine stops rotating, there is an adequate range of internal motion with respect to the lifter piston within its bore to allow the lifter to bleed down without the piston bottoming in its bore.  When this occurs, the valve spring pressure bearing down the length of the pushrod is relieved and the pushrod spins easily.  If the lifter rests higher on the ramp of the lobe when the engine stops rotating, the lifter will still collapse but will bottom out holding the valve off of its seat and the pushrod will be difficult to spin using your fingers.  As long as the valvetrain doesn't "clack" when the engine is started, there is no cause for alarm or worry.
Did these explanations adequately ease your concerns?
« Last Edit: April 26, 2020, 02:19:05 pm by bd »
Offline bigben5054
« Reply #5 on: May 20, 2020, 05:22:05 pm »
I am getting ready to reset my valves and found this thread while searching.  I had found some videos online and they made a big deal about setting preload on new lifters versus old lifters.  They said when you preload new lifters, you are pushing down on the lifter (which is good), but when you are setting preload on used lifters that have already pumped up you are pushing down on the valve (which is bad).
Is there a difference in how to set lifter preload on new lifters versus used lifters?
« Reply #6 on: May 21, 2020, 09:08:45 pm »
Adjust hydraulic lifters the same whether or not they contain oil.  Any lifter that contains oil already will bleed down within a few minutes of adjustment.
There are several methods for adjusting valves.  Choose the method you prefer or that is recommended for you camshaft and then be systematic and maintain consistency throughout the process.
Refer to the image previously posted.  Hydraulic lifters contain an internal plunger spring that will extend the plunger in the direction of the valve pushrod as the lifter is unloaded.  Once the plunger seats against its circlip retainer, backing off the valve adjustment further will create free-travel clearance that you can feel with your fingers as you move the pushrod axially, end-to-end.
With the lifter on the heel of its cam lobe, back the valve adjustment off until the pushrod moves end-to-end with ~0.030" of free-travel clearance.  The actual clearance is not important as long as you perceive it without question or doubt.  As you continuously move the pushrod end-to-end, gradually tighten the valve adjustment until the pushrod's free-travel clearance reduces to zero lash.  Tighten the adjustment an additional 1/2 - 1 full turn.  Although 1/2 turn typically is recommended, the actual preload is not critical as long as all valves are adjusted similarly.
Offline bigben5054
« Reply #7 on: May 21, 2020, 10:00:53 pm »
Thanks. The second sentence of you response confuses me.  Let’s say I got out right now and set all my valves at 1/2 turn preload.  You said they bleed down within a few minutes.  So if I get up tomorrow and recheck them they will all have bled down and be loose?  Then I have to reset them, and this time they shouldn’t bleed down?
« Reply #8 on: May 21, 2020, 10:23:31 pm »
If the valve is held off of its seat with the engine static, the lifter will bleed down over several minutes until either the valve is reseated or the plunger is bottomed within the lifter body.  Generally, cranking oil pressure will refill the lifter reservoirs before the engine restarts.  If the lifters are quite worn, they may clatter for a couple of seconds before quieting after the engine starts.  In effect, once the lifters are properly adjusted initially, they should not need it again.
