Author Topic: Western Chassis Drop...Dumb Q  (Read 6334 times)
Offline devildogmech
« on: April 24, 2020, 11:54:51 am »
Ok,
So I'm ALMOST done with my DROP!!!!!
Last on the list is the Forward Spring Hangers for the leaf springs.... Now I have dual side saddle fuel tanks.... The tanks are less than 2" away from the hangers... I have to get the rivets drilled/ ground down... I'm really trying NOT to take the bed off.....
Any suggestions on how to finagle this? I know someone here has done this!!!
TIA
Will
Be good, but not too good.
Offline FlatBlack77
Re: Western Chassis Drop...Dumb Q
« Reply #1 on: April 25, 2020, 11:45:15 am »
Sorry for the delay I forgot about this until an hour ago
I did this same drop a few years ago. I know I had removed the bed but couldnt remember having any trouble getting in there beside the fuel tank. I went through my old pictures and found that I had removed the fuel tank(single tank). It needed a new sending unit so it made sense to remove it at that time. For you I would suggest either removing the tanks, removing the bed, or possibly getting to the rivets from the inside of the frame rails. I dont remember how much room there is in there.
« Reply #2 on: April 30, 2020, 09:56:58 pm »
Whooo Hoo! Got the new mount points in!!!
Tools that make life so much easier!!!
https://www.matcotools.com/catalog/product/TCG225/thermostat-gasket-cleaner/
This little SOB... I've had it in my tool box for years, and never used it... This makes grinding the remains of the rivets down SO MUCH EASIER....Use a bunch of cheap 40 grit roll lock grinding pads....
https://www.harborfreight.com/air-tools-compressors/air-tools/3-in-high-speed-extended-reach-air-cutoff-tool-67996.html
This little $#*()..... oh yeah!!!! lets you get into places to clearance the bed rails... and cut the rivets into peices....
Pics soon!!! My dang drive shaft is frozen and wont collapse....
