Author Topic: Ignition Switch on a 1979 GMC Vandura 3500.  (Read 3346 times)
Offline JHolt
« on: April 24, 2020, 03:00:50 pm »
Need help please. The starter engages when the key is turned to the ON position and or the Accessory position. The ignition switch is dash mounted.
Offline MIKE S
  • Member
Re: Ignition Switch on a 1979 GMC Vandura 3500.
« Reply #1 on: April 24, 2020, 04:57:12 pm »
If you find you need an ignition switch, it is discontinued from GM. However there are at least 37 GM dealers in the U.S. that still show in inventory. Part# 12356033 Most G.M. dealers are willing to sell it to your local dealer. Also still available from aftermarket. Standard ignition# US84. Neither one will come with the key cylinder. Switch only.
