Author Topic: Proper stall converter- do I need a steeper stall?  (Read 7398 times)
Offline jc74868
  • 78 Silverado SWB
« on: April 29, 2020, 11:04:20 am »
Running 2400. Wondering if 2800-3000 would wake up my engine and be better suited to my setup. This is a street truck. Mainly just for fun, but I don't want my driveability and highway cruising to suffer too much
I have a '78 SWB C10 (approximately 3500 lbs)
Running a new Blueprint 430HP/450 torque  roller cam/roller rocker, big valve 383, new 700R4 transmission (1 wire lockup, constant pressure valvebody) with an FTI 2400 stall (2400 is what was recommended by my engine manufacturer), 3.73 rear gears.
I am really not impressed with this engine.  Doesn't really have much better takeoff than I did with the previous mild 350 (650 Holley, Edelbrock Performer, headers)/stock converter in the stock 700R4 that I ditched. It ran great, lots of tire smoking power.
This current setup does run good, sounds good, but definitely not the tire roasting beast I was expecting from a hopped up 383 stroker. Slightly more oomph at take off, but not much.
 **on a slightly different note, I have also noticed my RPMs in 4th gear are way higher than previously. With the old 700R4 & a factory type lockup system in place, it seems like I was cruising at about 1500 RPM at 70mph. Now it's closer to 2500RPM at 70mph...I'm assuming this has something to do with the higher stall, different lockup system, possibly something to do with the constant pressure valve?** I can live with that. I really want a more bombastic takeoff though.
Below are the full specs on my engine, including cam specs. I have switched their Edelbrock 7101 Performer RPM intake to an Edelbrock 7501 RPM AirGap and their Holley 750cfm to an Edelbrock 800cfm AVS II and running long tube headers in to Flowmasters.
BP38313CTC1D
ROTATING ASSEMBLY:
New BluePrint Cast steel crankshaft
3.750" Stroke
OEM type 5.700" connecting rods w/ 150,000 psi bolts
Hypereutectic pistons
External Front/ External Rear
CYLINDER HEADS:
BluePrint Aluminum Cylinder Heads - H8002K
64cc chamber
2.02" intake/1.60" exhaust valves
195cc intake/75cc exhaust runners
CAM SPECS:
Cam Type: Roller
.528 Intake .536 Exhaust
221 Intake / 226 Exhaust duration
@.050 - 110 degree lobe separation
« Last Edit: April 29, 2020, 11:21:41 am by jc74868 »
1978 Silverado SWB 383/700R4/3.73
Offline Stewart G Griffin
Re: Proper stall converter- do I need a steeper stall?
« Reply #1 on: April 29, 2020, 11:40:38 am »
This is just my totally inexperienced and uneducated opinion:
The cam is not too wild for a 383 at all.   Thus, no, you don't need  a higher stall converter and in fact the one you have now might even be too high.  (even though blueprint engines knows a lot more than me....).
Do they have the hp/tq curves posted anywhere?
Offline jc74868
  • 78 Silverado SWB
Offline jc74868
  • 78 Silverado SWB
« Reply #4 on: April 29, 2020, 11:50:12 am »
Sorry for posting this multiple times. Was trying to reply to you, but posted incorrectly and can't delete it. Here's the link to their HP/TQ chart:
https://cdn.shopify.com/s/files/1/2160/9839/products/BP38313CTC1D-dyno-chart_1903x.jpg?v=1580245640
« Reply #5 on: April 29, 2020, 11:58:54 am »
Does it idle ok in gear?
Offline jc74868
  • 78 Silverado SWB
« Reply #6 on: April 29, 2020, 12:10:35 pm »
I believe so.  Seems like about what I'm used to
« Reply #7 on: April 29, 2020, 12:24:35 pm »
You're sure you have 3.73?
Offline jc74868
  • 78 Silverado SWB
« Reply #8 on: April 29, 2020, 02:30:24 pm »
The original WAS 3.73, but a gear shattered and I changed out the entire differential years ago. I could swear that  I went with the same ratio. I'm pretty sure about that.  I'll  double check on that, because that would throw the entire equation off
Offline jc74868
  • 78 Silverado SWB
« Reply #9 on: May 03, 2020, 09:14:01 pm »
Well, you were on to something. I jacked up one side and check the ratio... I got barely over 3 driveshaft turns... It's somewhere in the 3.08-3.21 range. Definitely not the 3.73 I thought I was buying. I'm on the hunt for a 3.73 rear now and will double check before buying
« Reply #10 on: May 05, 2020, 10:18:41 am »
If you really want to roast 'em and since you have OD, we may want to consider 4:11 or even 4:56.    You should still have good rpms on the  highway.
Offline JohnnyPopper
  • Old Goof
« Reply #11 on: May 05, 2020, 04:36:15 pm »
What size tires are you turning?
1980 C-10 under construction
Offline FlatBlack77
« Reply #12 on: May 05, 2020, 07:32:35 pm »
I wouldnt hesitate to go deep to at least 4:11s like Stewart said. It would really wake it up
Offline jc74868
  • 78 Silverado SWB
« Reply #13 on: May 12, 2020, 01:59:12 pm »
275 60 15
Offline jc74868
  • 78 Silverado SWB
« Reply #14 on: May 12, 2020, 02:04:40 pm »
I just ran across a complete rear end with 4.10 gears. I really thought about it, but I've already thrown down on a new 3.73 ring and pinion I got a really good deal on. Got a new Yukon ring and pinion, pinion bearing, new seal and gasket for 130 bucks. Seemed like a good deal to me.  What I've got under it right now is an '85 or '86 10 bolt 3.08 that came out of a Suburban. I'd still like to go back with a 12 bolt C10 rear one of these days so it'd be closer to stock and maybe a little stronger
