Author Topic: '87 5.7L TBI Silverado - Crankcase vent tube issues  (Read 12920 times)
Offline All_American_C10s
« on: May 14, 2020, 04:26:14 pm »
I recently had a local shop replace the valve seals on my all stock 1987 throttle body injected 5.7L Silverado.  When I got her back, she ran fine but had little rougher idle than I remembered.  Then on my first time out on the interstate about a week later I realized the cruise was no longer working.  As I pulled the breather off, I quickly spotted that the crankcase vent rube running from the driver's side valve cover to the back of the throttle body was broken off flush with the valve cover.  I smoke tested the engine and only found one other small vacuum leak in the system.  I suspect this is my culprit.  The trouble is...you can't find this vent tube as a replacement part.  I've seen where it looks like others used a piece of vacuum or fuel line to make their own but I can't figure out how I would match that up with the grommet to get an adequate seal that would also not risk tubing sliding it's way down into the valve cover and interfering with the rockers.
Any ideas or suggestions on how to resolve this????
Shane Free
'87 5.7L Silverado every day driver
'67 C10 currently in restoration
Offline bigben5054
Re: '87 5.7L TBI Silverado - Crankcase vent tube issues
« Reply #1 on: May 15, 2020, 06:44:43 am »
Maybe I'm just not visualizing it correctly in my head, but are you just missing the PCV valve?
« Reply #2 on: May 15, 2020, 08:17:40 am »
No, sir.  It's the "L" shaped vent tube in the attached photo that runs from a grommet on the driver's side valve cover to the back of the throttle body.  There's no valve on this side.  The tube has been broken off flush with the valve cover grommet.
The pcv valve is mounted in the passenger side valve cover.
Sent from my SM-G977U using Tapatalk
Shane Free
Offline MIKE S
  • Member
« Reply #3 on: May 15, 2020, 09:06:58 am »
I see a vacuum line missing from the check valve going to the cruise control.
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: May 15, 2020, 09:41:36 am »
If you can't find that tube in a yard, it should be fairly simple to either fab one up, or braze yours back together.
98 C2500 ext cab longbed
« Reply #5 on: May 15, 2020, 09:49:27 am »
Yeah...I pulled that one to replace with new hose since it looked like it was on its last leg.
Shane Free
« Reply #6 on: May 15, 2020, 09:51:38 am »
No luck finding them in a yard so far.  You can find them,, but they are in worse shape than mine. Folks tend to break them off to get at the heads. 'm thinking about 3D printing one.  A buddy of mine has a printer.
Shane Free
« Reply #7 on: May 15, 2020, 09:52:57 am »
Fabricate it out of 1/2" soft aluminum or copper tubing and paint it satin black.  The missing vacuum line should connect the check valve at the top of the image to a single port manifold vacuum tree located behind the TBI assembly adjacent to the ignition coil.  It might behoove you to make a thorough inspection and look for any other problems introduced by the smog shop.
Offline bigben5054
« Reply #8 on: May 15, 2020, 09:56:22 am »
Run a search for Dorman 46001.  Is that it?
« Reply #9 on: May 15, 2020, 10:24:21 am »
Thought it was and picked one up but it didn't work.  That's the only part # the parts stores show as a replacement.
Shane Free
« Reply #10 on: May 15, 2020, 10:26:51 am »
Good call out.  I have a "smoke machine".  Each time I fix an issue/replace a line, I hook the smoke machine back up to check my work.  Usually end of finding another previously undiscovered issue to address.  By the time I'm done, I should have a brand new vacuum system!
Shane Free
Offline MIKE S
  • Member
« Reply #11 on: May 15, 2020, 10:32:41 am »
if you have good relationship with a GM dealer parts man,Part# 14102133 is the number of the tube. There are about 10 dealers in the USA that show to have it still. Have the parts man call one of these dealers and see if they will sell it.
« Reply #12 on: May 15, 2020, 10:35:14 am »
Thanks!  I knew it was discontinued butbI didn't think about inventory still sitting on the shelf out at dealerships somewhere.  I'll do that!
Shane Free
« Reply #13 on: May 15, 2020, 11:32:34 am »
If the local dealer doesn't want to arrange procurement of the part for you, (s)he should be able to provide a printout for the part that shows the "other" dealer addresses with phone numbers for you to call and arrange purchase directly.  Request a physical stock check and verify the selling price including an estimate for shipping.  A handful of dealers are quite proud of their "obsolete stock."
« Reply #14 on: May 15, 2020, 12:35:42 pm »
Thanks for the advice!  Local dealership got me in contact with a dealer in Center, TX.  They keep their obsolete stock in a separate building.  Said they'd check Monday and give me a call back.
Shane Free
