Author Topic: Spindle question  (Read 7233 times)
Offline geezy24
Spindle question
« on: May 15, 2020, 01:00:13 am »
Not sure if in the correct section, Mods please move to correct section if not.
Has anyone purchased and installed the cpp x10 extreme spindles for the their squarebody? I can not seem to get specs or answers to my questions when emailing them and not information listed on the site.
I would like to know if the hub can be found at a local parts store if replacement is needed, and the size hub bore if possible.
Thank you in advance
Offline geezy24
Spindle question
« Reply #1 on: May 15, 2020, 01:06:47 am »
Has anyone purchased the CPP x10 extreme spindles for a 73-87 Squarebody?
I can not get a straight answer from CPP on hub bore size and if the hubs are proprietary or can be found at a local parts store when replacement is needed.
Thank you for the help in advance
Offline FlatBlack77
Re: Spindle question
« Reply #2 on: May 15, 2020, 04:53:44 am »
If I am understanding you correctly you are trying to find the size of the hub that houses the wheel bearings. The part that goes through the center of the wheel.
That is part of the brake rotor. It is most likely purchased separately.
Or are you looking for the spindle shaft diameter?
Offline geezy24
« Reply #3 on: May 15, 2020, 06:30:10 am »
Cpp x10 extreme spindles come with sealed hubs.
What I want to know is the sizing of the hubs bore so I can figure out what chevy rotor fits since they will not tell me what truck the hub is from other that a late model 1500 truck. I tried every year of truck and they are all 6 lug.
I also would like to know if the hub is only availble thru cpp when replacement is needed or can it be bought at a common auto parts store
Offline FlatBlack77
« Reply #4 on: May 15, 2020, 12:22:25 pm »
Ahhh I see what you are saying. My mistake for assuming they were like traditional spindles.
Offline Da67goatman
  • Burban
« Reply #5 on: May 15, 2020, 12:55:39 pm »
Looks like a 88-98 2wd hub though I haven't laid eyes on one to confirm.  That bodystyle used a 3 bolt sealed hub.  Vile Probably knows off hand
<Pitcrew>
