Author Topic: Is there any trick to install the manual 3 speed transmission?  (Read 5801 times)
Offline ChrisD
Hi,
i'm just back from lying under my car.
I installed the new clutch and bell housing and then i tried to thread the transmission through the clutch disc into the pilot bushing.
My problem is, that i can't lift the car up, so i put the transmission on to a car jack an then rolled it in direction of its final destination.
the last inch i had to put it manually, but i turned it, put it back and forth but exept that my arms become tired there wasn't any result.
What can i do to get the the drive gear through the clutch disc and into the pilot bushing more easy?
regards
chris
1978 Chevy C10 short bed with 250i6 and manual 3speed Saginaw
German us-car/truck newbie
Re: Is there any trick to install the manual 3 speed transmission?
« Reply #1 on: May 15, 2020, 01:29:58 pm »
Did you properly center the clutch disc to the pilot bearing using a clutch alignment tool?
Offline ChrisD
« Reply #2 on: May 15, 2020, 02:22:31 pm »
Hi,
yes the alignment tool was with the clutch kit and i used it.
After i couldn't enter the transmission, i put it back and it wasn't a problem.
Is it a bad idea to do some lube to the drive gear?
regards
Chris
Offline Poppy 87
« Reply #3 on: May 15, 2020, 02:33:47 pm »
Hi,
regards
Chris
Does the alignment tool match the input shaft exactly?
Sent from my XT1254 using Tapatalk
Offline ChrisD
« Reply #4 on: May 15, 2020, 02:43:38 pm »
Good question, I will check this tomorrow, here it's nearly 10 PM.
Thank you!
Chris
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: May 15, 2020, 05:30:25 pm »
If it matches, good.
I have put the trans in gear and used a yoke on the drive shaft to turn the input shaft from the output shaft.
Also, if you have a prob with getting that last 1" into the pilot bearing, have someone sit in the drivers seat and depress the clutch.
1980 C-10 under construction
Offline ChrisD
« Reply #6 on: May 16, 2020, 12:50:36 pm »
Hi,
the transmission is back in his position! I checked if the size of drive gear and the allignment tool have the same size ajusted the release bearing once more and, perhaps also because it was the first thing i did at the car, the drive gear slipped throug the clutch.
For the last zentimeter (I don't know how to say 0,39 zoll) i used a small board, 24 long with a score so that it couldn't slip away from the clutch pedalto keep the pedal pushed. Thanks Johnny for this tip!
Thank you all, for your replies and help!
regards
Chris
« Last Edit: May 16, 2020, 05:00:10 pm by ChrisD »
  • Old Goof
« Reply #7 on: May 17, 2020, 02:49:55 pm »
Good job Chris! glad it worked!
