Author Topic: 1984 C-10 Custom Deluxe  (Read 250186 times)
Offline macr0w
Re: 1984 C-10 Custom Deluxe
« Reply #105 on: June 18, 2023, 07:39:34 pm »
 8)
I went to the Piedmont Traction show this past Saturday.
It was great.
C10's and other Chevy trucks as far as the eye could see.
 8)
Offline macr0w
« Reply #106 on: July 18, 2023, 06:29:50 pm »
My truck randomly and suddenly shut off this past Saturday after running great. After some quick trouble shooting I figured out that the fuel pump was not running. I have pulled the fuel tank in and out of this truck more times than I care to count. This time I opted to pull the bed off. After some further testing I found a broken ground wire. I fixed it and she fired right up. Since the bed was off I took the time to do some cleanup. Straightened out some wiring and re-routed my fuel lines. Then I pressure washed everything real good. Then I ended up replacing some tail light bulbs and fixed my right front turn signal.
She's ready to roll. 😎
Offline macr0w
« Reply #107 on: July 18, 2023, 06:45:27 pm »
When I get ready to really do the paint I will do the frame and everything underneath.
For now I just want to drive it.  8)
My pics won't load. I'll get them posted tomorrow.
Online JohnnyPopper
  • Old Goof
« Reply #108 on: July 18, 2023, 09:49:08 pm »
Nice job man, we feel the energy!
1980 C-10 under construction
Offline macr0w
« Reply #109 on: July 28, 2023, 07:45:45 am »
Alright, let's see if I can post some pics.  8)
Offline macr0w
« Reply #110 on: July 28, 2023, 07:49:29 am »
I should have taken a picture of it after pressure washing the frame and everything.  :P
Offline macr0w
« Reply #111 on: July 28, 2023, 08:11:48 am »
As she currently sits.
After doing the Belltech 2"/4" drop kit, the front end didn't go down a whole lot.
The rear went down significantly. I actually had to raise it up a notch.
Offline Shifty
  • I bleed Bowtie red...
« Reply #112 on: July 28, 2023, 11:08:43 am »
Love it!  8)
98 C2500 ext cab longbed
Online JohnnyPopper
  • Old Goof
« Reply #113 on: July 28, 2023, 07:30:07 pm »
Nice work!
If she were my gal I would lay down a flat/matte clear coat to preserve the patina.
Offline macr0w
« Reply #114 on: July 29, 2023, 07:12:25 pm »
Nice work!
You know....
That is definitely the style these days.
I understand it but, I'm not into it really. It's just not me.
Maybe if this truck had a more eve and natural patina it would be different.
I am actually looking forward to getting it painted back the "light blue metallic" it rolled out of the factory with.  8)
Offline Shifty
« Reply #115 on: July 31, 2023, 09:26:33 am »
Nice work!
You know....
I'm with you on the clear-coat thing...just doesn't look right.
Offline macr0w
« Reply #116 on: August 05, 2023, 06:40:23 am »
He guys, I added some of these speaker brackets for my 6"x9"s. I marked and drilled the necessary holes in them and then scuff sanded them. Then, I sprayed them with rubberized bedliner stuff to kind of deaden them so they don't resonate. I stuffed the holes behind them with a moving blanket. Rocking some tunes in the Blue Beast.
I also ordered a Belltech swaybar kit to go with the shocks and everything else I did last month.
I try to keep a steady flow of cash aimed at my truck.  ;D
Offline Mike81K10
« Reply #117 on: August 05, 2023, 09:22:48 am »
Looks good and rock on!
Offline Shifty
« Reply #118 on: August 07, 2023, 02:41:32 pm »
 8)
Offline macr0w
« Reply #119 on: August 13, 2023, 10:15:07 am »
Front and rear anti-sway bar installation is complete.
She's rolling flat.
It feels good.  8)
