Author Topic: signal light problems  (Read 3264 times)
Offline KeithBradley
« on: May 31, 2020, 06:31:14 am »
Hi All Went using my signal lights the rear ones work fine but the front both flash along the marker lights. The grounds on the header panel are both good. Any suggestions. Truck is 1985 chevy c10 Thanks Keith
Re: signal light problems
« Reply #1 on: May 31, 2020, 12:10:46 pm »
The front side markers are supposed to flash with the turn signals.  The front markers should flash coincidentally with the front turn signals when the running lights are switched OFF.  They should flash alternately with the front turn signals when the running lights are switched ON.
