Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
Suburban AC install and upgrade
Topic: Suburban AC install and upgrade (Read 7669 times)
swissarmychainsaw
June 05, 2020, 10:57:03 am »
Hey Gang,
1976 GMC Suburban
2008 LS 6.0 with Carb and MSD
TH350 203 transfer case
Blue and Silver!
This truck is a factory air truck, no rear air, but when the LS was installed by the PO all the AC stuff was removed.
I have taken a vow to get AC working again on this thing AND to install a rear AC unit on it.!
I source a rear unit, and (eventually) did the right thing and called "Classic Auto Air" for guidance on the compressor size and other things. Mike O there put a kit together for me and I'm installing it now.
My question is this:
How do you mount a parallel flow condenser?
the brackets I got seem not very helpful.
Kinda like this:
Before I started this project I knew nothing about Air Conditioning, but I'm getting there
thanks!
Nick
Last Edit: June 05, 2020, 11:21:57 am by swissarmychainsaw
Da67goatman
Site Supporters
Burban
Re: Suburban AC install and upgrade
June 05, 2020, 12:35:09 pm »
Sorry I can't help, I don't know jack about A/C but I do really want to see the finished product after you get it all together
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
bd
June 05, 2020, 02:08:46 pm »
The condenser installs in front of the radiator similar to the factory configuration. However, you may need to fabricate custom mounts to ensure easy accessibility for attaching and/or servicing the lines and to guarantee suitable clearance with the radiator.
Link:
Serpentine conversion A/C question
Last Edit: June 06, 2020, 10:16:42 am by bd
swissarmychainsaw
June 09, 2020, 03:49:49 pm »
I'm doing a full court press on this system.
Here is the mount for the condenser.
I have all the lines fabbed up and am trying to get everything to seal tight.
Next is the wiring, which is ... troublesome.
swissarmychainsaw
June 11, 2020, 12:04:52 pm »
I need to add about 3 oz of PAG oil to this system.
I arrived at that number by looking at the manual and talking to the sales/tech, the original system (with dual AC!) had 3 oz more then the since evap system.
So assuming the compressor has enough oil in it for a single AC system, we then will add 3 oz for a dual.
How should I add the oil?
I need to pull a vacuum on it anyway, so it's open, now.
I'm seriously considering opening one of the rear lines and just pouring 3 oz in.
Considering the rear lines are 15 feet long, I don't think it should be a problem.
bd
June 11, 2020, 12:31:14 pm »
Does the system already contain PAG oil? DO NOT MIX different types of refrigerant oil!
As long as the existing oil is PAG just dump it into the accumulator.
