Author Topic: THERMAC and heat riser  (Read 4786 times)
Offline TB24
« on: June 14, 2020, 01:21:26 pm »
1984 K10 Silverado
Hey everyone, I am wanting to return my truck to stock type thermac including the heat stove and exhaust heat riser. I am having a hard time finding these items online. I could probably fabricate the heat stove relatively easy but when it comes to the heat riser I am sort of lost. It gets pretty cold here in Ohio and I’d like to have cold weather drivability. Any leads would be appreciated!
73 K10 Custom 350/sm465/np208
84 K10 Silverado 350/sm465/np208
Offline JohnnyPopper
  • Old Goof
Re: THERMAC and heat riser
« Reply #1 on: June 14, 2020, 01:56:29 pm »
does your air cleaner have the thermac valve and sensor?
You can fab up a sheet metal collector on the exhaust and steel tube it up to the air cleaner.
1980 C-10 under construction
Offline rla98
« Reply #2 on: June 14, 2020, 02:02:14 pm »
Hello!
I have a 1976 Chevy K10 that was in need of a new heat riser and gasket which I ordered from Summit Racing. I called them and they were very helpful.
As for the heat stove I would do a junk yard search on line. I have gotten several parts that way.
By the way my quadrajet works great, even in the winter!
Good Luck!
R.L.
Offline Stewart G Griffin
« Reply #3 on: September 13, 2020, 09:46:33 pm »
carpart.com
ebay
facebook
