Author Topic: 700R4  (Read 6468 times)
Offline scott dale
700R4
« on: December 25, 2005, 02:15:00 am »
I made the switch from the 350C to 700R4 in my 86 scottsdale and to be honest its like a new truck. Soon the 273 rear will be swapped out.
Offline chuck4shore
Re: 700R4
« Reply #1 on: November 09, 2006, 07:32:00 pm »
what type of mods did you have to do
Offline shaved80
Re: 700R4
« Reply #2 on: November 10, 2006, 01:56:00 am »
amen to that!
Offline 80stepsideguy
Re: 700R4
« Reply #3 on: November 10, 2006, 07:47:00 pm »
yes please give us a list what we need to do this..I am building a 80 and it had a th350 and i want to go with the 700r4 setup since i am running a 3.73 rearend..
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline shaved80
Re: 700R4
« Reply #4 on: November 10, 2006, 09:52:00 pm »
you move the tranny xmember back 1.5" or so, to pre drilled holes (i think they were drilled starting at 80, but someone can correct me) and shorten the driveshaft 3"
Offline bowtieguy
  • Country as a Cow Pie
Re: 700R4
« Reply #5 on: November 11, 2006, 12:32:00 pm »
I put a 700R4 in my 79 this fall.  It is a HUGE hit with me!  It did indeed make it a different truck.  Just HUMS down the road.
I had to drill 4 holes.  3 in the frame and 1 in the x-member for the tranny to mount.  If you don't want to mess with elec speedo get a 87 or under tranny.  I have a 90 tranny and I am going to have to use a elec speedo or remove the tail shaft and remove all of the speed pick up peices and replace with manual cable speedo.  Still havn't descided.  GPS works for now LOL!!
Make sure to get a good name brand lock up kit.  Bowtie overdrives, painless etc...  I have the B.O. kit and it works great, took a hole 20 minutes to wire it from the tranny to the cab and under dash.
I used a B&M trans pack kit in the tranny too. (Recomended!!!)  It shifts NICE!  and if you plan to even haul a 4 wheeler in the back use a Shift reprogramer kit of your choice.  I did my kit on a saturday morning, just find a clean place to do it and a good drill.
Its worth the hastle for a 700R4!
Toys:
89 Black Lesabre T 62k miles
03 Lesabre Celebration Edition
08 NNBS CC Z71 LTZ
79 Flat BlackChevy C-10  5.3/4L60E
