Author Topic: Please Delete  (Read 12529 times)
Offline Bunkerbuilder
  • OldManOfTheSea.
Please Delete
« on: June 17, 2020, 11:23:13 pm »
« Last Edit: August 06, 2020, 05:36:20 pm by Bunkerbuilder »
2007 Chevrolet Silverado K3500
1984 M1028 496,NV4500,NP205.
1986 M1008 6.2L,THM400,NP205. < Was T boned totalled by ins co, parting out.
1986 M1031 MTY DRIVETRAIN
Offline JAH
I have two '86 regular cab K30 duallies.  One of 'em (Rico) is a SM465/205 combo, and happens to be parked in the garage tonight.  The other (Max) has been at my Cousin's P&B shop for the last eight-or-so months. >:(
Anyhoo, your thread had me curious.  So, I ran-out to the garage, a few minutes back, and shined the flashlight onto Rico's belly.  On my truck, the droops in the crossmember are symmetrical toward the deck.
I you need me to, I can snap a pic or two of the C/M. (*I also know a guy [locally] who has about a billion scavenged parts, from several Square Body trucks.  I'm not going to promise anything.  But, I may be able to source one, if you are willing to spring for the price+shipping.  I'd only do this because I know the PIA of finding certain parts.)
Lemme' know if I can help,
J.J.
EDIT- One of the things that clued me is the skid-plate in your pic.  I've owned enough K30s to know that the skid-plate in your pic ain't the right one.
« Last Edit: June 18, 2020, 01:45:23 am by JAH »
I spent most of my money on Jack Daniel's, Copenhagen, pocket knives, and 4X4 trucks.  The rest I just wasted.
  • OldManOfTheSea.
Yes pictures and knowledge of the same setup would be very much appreciated.
And yes I would be fine with covering the cost and shipping.
Im assuming your truck (Rico) is a 32 spline sm465 and a 6 bolt round pattern adapter and transfer case.
This seems to be key as to the location of the height of where the adapter mounts and the style of mount being the newer one piece and not the old style that sandwiched the flat crossmember.
The height of the wood block under the adapter is approximately 5.5 inches.
« Last Edit: June 18, 2020, 01:12:44 pm by Bunkerbuilder »
Offline JAH
Hey Bb,
Sorry I haven't gotten back with you.  My week exploded after I posted the other night.
I hope to be in the truck today, and will try to get a pic or two.
J.J.
  • OldManOfTheSea.
« Reply #4 on: June 19, 2020, 06:21:45 pm »
« Last Edit: August 06, 2020, 05:38:16 pm by Bunkerbuilder »
Offline JAH
Okay, here we go...
Because my truck is an '86, my 205 is the six bolt pattern. (*I tried to get a better pic, but would need an arm shaped like the letter "Z")   Mine was built and stamped on 03-10-86.
Offline JAH
Here is the cross-member and 'case bushing/spacer...
Offline JAH
If you need anything else, lemme' know.
...and "Big Daddy" Rico says, "You're welcome."  ;)
  • OldManOfTheSea.
« Reply #8 on: June 19, 2020, 09:02:48 pm »
« Last Edit: August 06, 2020, 05:38:55 pm by Bunkerbuilder »
Offline JAH
Thanks.  I humbly agree that Rico is handsome.  And yes, he has the 60F/70HD combo...which was pretty standard for the K30 duallies.
The crossmember you posted is the one for which I will look.  I'm not going to promise anything, but will tell you that, even as late as a year ago, the guy I posted about was doing a lot of selling and trading locally.  I'm pretty busy, as is he (being a Commercial/Master Plumber).  So, it may be a few days before I find him away from one of his many jobs. (*Construction is CRAZY right now, in and around San Antone)
  • OldManOfTheSea.
I dont have any other possibles so, its this venue or it gets really hard.
I had a crossmember in that shape but the man that removed the parts from the donor didnt support the transmission correctly and the crossmember was mangeled.
Thanks for your help.
Offline JAH
Hey Buddy, I just sent you a message.  I can't tell if it went through.  So, please let me know if you received it.
Saludos,
J.J.
  • OldManOfTheSea.
Saw it in email and received notice in the forum.
Thanks very much..
ps > we are in contact.
I have a few CUCV parts and a C30 gmc crew cab dually frame if you need any parts let me know.
« Last Edit: June 25, 2020, 11:19:14 am by Bunkerbuilder »
Offline JAH
Thanks very much..
Thanks, Buddy.
I hope my info helps.  Happy hunting! :)
  • OldManOfTheSea.
Well I found a crossmember that mounts the transmission adapter correctly but its not the ultimate one and I am holding out for the W crossmember that hopefully will let me use the exhaust in its current configuration and not require modification via a muffler shop.
So again looking for the W crossmember..
Pictures of it are posted below.
Thanks again for any assist.
« Last Edit: July 14, 2020, 05:47:23 pm by Bunkerbuilder »
