Author Topic: Stock motor mount Max Hp / Tq  (Read 3247 times)
Offline Curt80
« on: June 18, 2020, 12:03:49 pm »
Hello all,
I'm overhauling my 1980 1/2 ton 2wd Shortbox. Building a new powerplant, wondering if my motor mounts will hold or if it's the time for a stronger setup.
I currently have the stock mount setup upgraded with poly clamshell inserts.  Does anyone have a rough idea of what a stock setup like this will hold?  Old motor was 400 hp / 400 ft.lbs with no issues so far, the new motor is in the 500 hp / 550 ft.lbs range.  The truck has a strong driveline and does hook up decent so it's not just a tire spinner.
I can't seem to find a pre-fabed kit for a 73-87 so any knowledge of one, or real world failures (and their ballpark tq.) is appreciated.
Re: Stock motor mount Max Hp / Tq
« Reply #1 on: June 18, 2020, 05:37:02 pm »
While not a drag racer, I can only comment on what I haven't heard of is motor mount failures.  The design of it is so much better than the 67-72 which did have failures.  I've had well over 100 of these and been in the hobby for 25+years.  Never heard of an issue
Offline Curt80
« Reply #2 on: June 19, 2020, 09:36:39 pm »
That's a good way of looking at it, thanks
