Author Topic: Best Head Gaskets  (Read 16264 times)
Offline JohnnyPopper
  • Old Goof
Best Head Gaskets
« on: June 19, 2020, 09:04:38 pm »
I'm getting ready to land the heads, looked at the gaskets in the 'kit' I bought last year, they look anemic.
Any thought on this, based on experience?
Did a search and this PN came up: 10185054
Thanks in advance as usual!
1980 C-10 under construction
  • Old Goof
Re: Best Head Gaskets
« Reply #1 on: June 19, 2020, 09:30:08 pm »
I found some NOS on Ebay, GM packaging.
Does anyone think aftermarket are better?
TY  8)
Offline ehjorten
« Reply #2 on: June 19, 2020, 10:10:43 pm »
What heads to what engine?
-Erik-
  • Old Goof
« Reply #3 on: June 20, 2020, 06:44:23 pm »
Cast iron heads, OEM off a 350, 383 lower end
I know, I know, for a little more $ you can fly first class... ::)
  • Old Goof
« Reply #4 on: June 20, 2020, 06:45:30 pm »
Just to add, I drove the Z28 it came out of...scary fast 8)
Offline bigben5054
« Reply #5 on: June 22, 2020, 09:58:27 am »
I'm no expert on head gaskets, but personally I would go aftermarket over NOS.  I don't know if head gaskets have a "shelf life" but it seems risky to me.  Especially when you typically pay more for NOS than aftermarket.  I trust Fel-Pro's stuff.  Another thing I learned recently was that you are supposed to use the correct gasket thickness for your motor.  You should aim for .035-.045 quench.  So step one should be to measure how far down in the hole your pistons sit at TDC.  Then choose the correct thickness gasket to get you in that range.  For example, my pistons were down about .025, so I bought the steel shim gaskets that are .016, to give me .041 quench.  I sprayed the gaskets with the copper gasket stuff before installing.
  • Old Goof
« Reply #6 on: June 22, 2020, 04:26:59 pm »
Thanks BB, I'll start there. I use the copper stuff too, for like 40 years... 8)
  • Old Goof
« Reply #7 on: July 14, 2020, 11:14:23 pm »
Just measured the drop of my pistons, well on No. 1. It's sitting .045 below the block.
That doesn't sound good from your last post. Any ideas?
Thanks!
Offline bigben5054
« Reply #8 on: July 16, 2020, 02:40:52 pm »
Perhaps it was rebuilt once upon a time and someone used pistons with a shorter compression height.  Stock pistons have a 1.560 compression height.  I'd bet yours are 1.540.  You could pull them and measure.  Either way, there are really only 3 options.  1) have the block deck milled; 2) get pistons with the proper piston height; or 3) run it!  If you used steel shims you'd be around .060.  Maybe someone else can weigh in, but I'm sure there are plenty of old SBC's out there running up and down the streets just fine with quench in that range.
  • Old Goof
« Reply #9 on: July 16, 2020, 06:28:22 pm »
Thanks BB!
It was rebuilt before I got it, so we'll just go with that and RUN it!
When you say shim at .060, you are talking about metal head gaskets?
Hate to sound like a dweeb but there is still some jargon on this board that I don't synch up with... ::)
Offline bigben5054
« Reply #10 on: July 21, 2020, 04:41:13 pm »
I just mean that the head gasket thickness gets added to the .045 you already have.  I *think* the thinnest head gasket option is the steel shim gaskets which are .016.
  • Old Goof
« Reply #11 on: July 21, 2020, 08:42:44 pm »
Thanks again! I'm slowly getting it... :-[
Offline frotosride
    • WFO CONCEPTS
« Reply #12 on: July 21, 2020, 10:10:08 pm »
Yup id defiantly run it to. I would run it if I didn't have a set of Pistons laying around with a better height and they would have to be floating rods. Other than that I wouldn't spend the time to fix this issue.
On a non related topic...
I Wanna see that Apache!
  • Old Goof
« Reply #13 on: August 06, 2020, 05:26:53 pm »
Would anyone know who makes them? Just called Napa, their only choices are .039 and .041
Thanks!!!
  • Old Goof
« Reply #14 on: August 06, 2020, 05:46:50 pm »
Felpro 7733-SH1
.013-.016
33.00 pair at Napa Auto
Thanks Guys!
