Author Topic: ALCL Connector Location for a 86 K30?  (Read 3942 times)
Offline DouglasBeale
« on: June 25, 2020, 08:04:38 am »
The service manual says: The Assembly Line Communication Link (ALCL) is a diagnostic connector located in the passenger compartment...
I can't find it anywhere??? Pulled glove box, small panel under steering, ash tray.
1986 Chevy K30
4WD Dually
Four Speed 117mm Transmission
NP205 transfer case
Quadrajet
Offline MIKE S
  • Member
Re: ALCL Connector Location for a 86 K30?
« Reply #1 on: June 25, 2020, 08:43:05 am »
If you have one it is on the left side of dash next to the emergency brake release pull. But Your vehicle may not have a computer system since it is a 30 series. If it has a computer it should be mounted above the heater box at the cowl behind glovebox.
« Reply #2 on: June 25, 2020, 08:50:57 am »
Don't see either... that would explain why I cant find it.
Thank you Mike.
1986 Chevy K30
4WD Dually
NP205 transfer case
Quadrajet
