Author Topic: Discharge pressure cutout switch  (Read 12632 times)
Offline MIKE S
  • Member
Re: Discharge pressure cutout switch
« Reply #15 on: August 05, 2020, 02:43:46 pm »
Make sure you have a separate ground wire from one of the blower motor mounting screws to body ground. Remember the motor is mounted on a fiberglass housing. Make sure grounds are clean.
Offline runnergeorge
« Reply #16 on: August 05, 2020, 08:03:59 pm »
That’s the first place I looked and they were all clean. And actually the shop described it incorrectly, the blower motor was blowing but the compressor clutch was not engaging. It turned out to be a simple loose connection!
