Author Topic: I'm looking for the Screw & nut mirror mount 'A' parts,  (Read 5413 times)
Offline jntrndrm
« on: July 18, 2020, 09:46:03 am »
Anyone know to get them?  These are the 3 mounts for the screws that fasten the mirror bracket to the door skin.
« Last Edit: July 19, 2020, 06:17:38 am by jntrndrm »
Re: I'm looking for the Screw & nut mirror mount 'A' parts,
« Reply #1 on: July 18, 2020, 11:44:25 am »
You are going to have to ask the question so it makes sense.  For the life of me I have no idea what you are looking for???
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: July 18, 2020, 01:31:38 pm »
 :o
1980 C-10 under construction
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: July 20, 2020, 09:46:12 pm »
The top two bolt holes normally have 2 plastic inserts that are attached to the door, no nuts. The lower hole has a brace that is attached behind the door card on one end to the inside of the door the other end of the brace reaches to the outer skin and has a nut attached for the lower mount hole. Don't forget your gasket!
Offline MIKE S
  • Member
« Reply #4 on: July 20, 2020, 10:12:07 pm »
Most of the squarebody suppliers have them. Look online in the mirror section.
Online bd
« Reply #5 on: July 20, 2020, 11:10:09 pm »
Google "jack nuts."  Use the type that is coated.  The coating functions as a seal.
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: July 27, 2020, 11:32:27 pm »
You will see a picture of 4 kids... Those are mine scroll down.
