Author Topic: Swap F&R diff between 76 K25 and 81 K20 truck  (Read 5824 times)
Offline Mark
  • driver is a 1981 K20, spares 1976 K25 & C25
« on: September 10, 2020, 06:06:39 pm »
I have a 1976 K25 parts truck and wish to swat the F&R differentials into my 1981 K20 truck. My question is this doable or do I need to also change drivelines? The trucks have different transfer cases too.
Thanks for any help you can provide in this project
Offline JohnnyPopper
  • Old Goof
Re: Swap F&R diff between 76 K25 and 81 K20 truck
« Reply #1 on: September 11, 2020, 02:37:07 pm »
It will probably work, but what are you gaining?
Different ratio, lower miles?
If the 76 has a NP203 transfer case you'll want to install a part time Kit and locking hubs, or expect already bad mileage to be worse.
Are the wheel bases the same?
Inquiring minds want to know...
1980 C-10 under construction
