Author Topic: Aerosal paint for my white 1987 R10  (Read 5892 times)
Offline mmanship
« on: September 25, 2020, 06:38:54 pm »
Dupont indicates their code for the white was 817.  The mfg code seems to be 12/5111.   Does anyone know of a provider for aerosal paint for our older trucks?
Offline Ed4all10
Re: Aerosal paint for my white 1987 R10
« Reply #1 on: September 25, 2020, 08:18:02 pm »
Best bet is to check with the dealer....that’s assuming that it has never been repainted. Depending on the condition of your rig, you might want to try and find a local paint shop that will allow you to do your own prep work. Then have them spray it for you. Saves a lot of money, because The prep work takes more time than the actual painting.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: September 25, 2020, 08:46:11 pm »
Automotivetouchup.com
You're welcome 8)
1980 C-10 under construction
Offline danmandan
« Reply #3 on: September 28, 2020, 07:51:57 am »
 Try ,,  expresspaint.com  ,,,,,,I've had good luck with them ,,, and the paint does come pretty fast
Offline DanMcG
Offline Da67goatman
  • Burban
« Reply #5 on: September 29, 2020, 08:35:29 am »
You're welcome 8)
I've used these guys on vehicles in the past and it was perfect match.  Depending on how much you need I believe Eastwood sells a DIY aerosol  where you mix the paint just like a HVLP but strain it into their spray can.
<Pitcrew>
Offline Mike81K10
« Reply #6 on: October 01, 2020, 07:53:40 pm »
You will find your paint at automotivetouchup.com and the link is below. I have attached a picture with your paint code. I have had very good luck with them. You can get 12 oz cans or smaller cans and if desired bottles of paint with a brush.
https://www.automotivetouchup.com/spray_paint_matched.aspx
« Last Edit: October 02, 2020, 12:32:01 pm by Mike81K10 »
