Author Topic: Yet another temp gauge question!  (Read 6974 times)
Offline MikecLA
« on: October 15, 2020, 12:50:30 pm »
OK so Ive done it all right according to posts here etc.. What is normal operating range on this specific gauge? , 74-76? . Ive got a new gauge w resistor, proper new sending unit per forum and (Ive tried generic ac delco one.as well but it was lower reading) new 195 tstat., 4 core radiator and 307 engine.
 -its running warmed up temp is at 1st. 1/4 mark normal driving  , close to 1/2 when t stat opens at 195.
- im running a mechanical gauge as well to verify this.
-i assumed 1/2 would be 125 as hot is 250 but looking at next gen gauge 1/2 way is not that.
So i think for a factory gauge 1/4 mark is "normal". Gauges were never that accurate and any newer vehicle purposely gauges low as not to panic the consumer. Is that the case here you think? whats your truck run  for normal?  thanks!
Offline bd
Re: Yet another temp gauge question!
« Reply #1 on: October 18, 2020, 02:34:35 pm »
Correct.  The temperature gauge scale is nonlinear.  Normal, 195° F, is between 1/4 and 1/2 scale.
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: October 18, 2020, 03:39:53 pm »
Mine runs at the first mark normally. In the summer using AC, it will get to the middle mark and sometimes a little over without over heating.
Mopar by Birth
Chevy by Choice
Offline MikecLA
« Reply #3 on: October 18, 2020, 04:51:20 pm »
thanks guys. Getting the A/C working next, see if that affects the temp. might switch to a 165 t-stat if so.
Offline bd
« Reply #4 on: October 18, 2020, 04:54:50 pm »
As long as you have a four-core radiator with good airflow, your truck should have zero cooling problems.  Stick with the 195° t-stat.
