Author Topic: 350 Heavy Duty?  (Read 4005 times)
Offline 77GMCSerria
350 Heavy Duty?
« on: December 14, 2006, 02:16:00 pm »
What exactly makes a 350 a heay duty 350? Is it a 4 bolt main or special heads or intake?
The motor was in a 81 K30 Crew Cab Dually with a auto tranny.
Thanks
Offline roundedline
Re: 350 Heavy Duty?
« Reply #1 on: December 14, 2006, 03:12:00 pm »
Typically 1 tons had 4 bolts, but I have see several that didn't, so don't count on it.  The 20/30 series trucks had valvtrains designed for low rpm to make pulling power and typically small valves.  For 1981 they had .1 extra compression (8.2 vs 8.3)
The block in itself is nothing special though.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
