Author Topic: 78 C10 Backspacing/Wheel question  (Read 6363 times)
Offline miket007
« on: December 06, 2020, 10:31:44 pm »
Hey Guys...I am looking to go with some old school slotted mags...the US Mags indy...15X9 on the front and 15X10 in the rear....78 C10 2wd Big ten. The 15X9 shows a -12 offset 4.5 backspacing...test fitting one, I find the outer part of the tie rod end at the knuckle just barely touches the inside of the wheel....seems like 1/16" clearanced off the rod end end would make it fly.
Anyone have experience using the 15X9 4.50 on the front, 15X10 3.50 on the back?
« Last Edit: December 06, 2020, 10:39:28 pm by miket007 »
78 C-10 Silverado Big Ten
A/C, Tilt, 350/350, posi Two-Tone
Headers, 2.5" duals with Dynomax 17749's
Offline OilBurner
Re: 78 C10 Backspacing/Wheel question
« Reply #1 on: December 10, 2020, 03:52:35 am »
i personally havent run anything that wide on any of my trucks, but if you just need a 16th you could get an 1/8 inch spacer for the front that would slide on the wheel mounting surface between the rotor and the wheel.
these are like 10 bucks at summitt
Allstar Performance ALL44125 1/8" Steel Wheel Spacer
1982 crew cab, 12 valve cummins, eaton 10 speed, married transfer case, custom coil spring front 4wd suspension, work in progress
