Author Topic: Need help identify a plug.  (Read 4614 times)
Offline Danevineyard
« on: January 15, 2021, 06:49:05 pm »
So I am going through and redoing some of the electrical on my 1973 Chevy G20 van and I found this plug melted to the side of my engine block. Can anyone help me identify it when I found it the plug that was in it had four wires coming out the end there seemed to all be wired together but then I took it out and subsequently lost the piece with the wires that were together. So I need help identifying what plug this is so that perhaps I can replace it and maybe restore it so it's not rigged all funny
Offline Spool
Re: Need help identify a plug.
« Reply #1 on: January 18, 2021, 08:43:38 pm »
I don't have the answer, but I came across the very same question today on my 73 c20.
And I'd like to share my photo with the same interest.
I have 3 of these connections:
-The one in question is disconnected: What is its function?
-A second connected right into the firewall beside the bulkhead: What is its function?
-A third between the first two: What is its function?
Offline DanMcG
« Reply #2 on: January 19, 2021, 05:12:33 am »
rear lighting harness? do your lights work?
« Reply #3 on: January 19, 2021, 05:48:41 pm »
Yes my lights work but when I lost the plug my engine won't even turn over anymore. Whereas before it would turn over but not start
« Reply #4 on: January 19, 2021, 05:51:18 pm »
The wires coming out of it are green, light green, and two brown wires.
Offline 75gmck25
« Reply #5 on: March 05, 2021, 10:29:39 am »
Some of the colors you have are standard for the lighting circuit. Take a look at this link.  http://www.chuckschevytruckpages.com/80hlightschematic.html
Bruce
« Last Edit: March 05, 2021, 10:33:40 am by 75gmck25 »
Offline JohnnyPopper
  • Old Goof
« Reply #6 on: March 05, 2021, 01:28:39 pm »
It doesn't look like it's burned beyond use.
Take a razor knife and clean up the burned areas, use some brake cleaner to clean out the gunk.
Then plug it in and get on with life  ;)
1980 C-10 under construction
