Author Topic: Power steering pump/high pressure hose  (Read 5463 times)
Offline GMJager
« on: January 21, 2021, 04:31:18 am »
So i picked up my first squarebody over the weekend, drove it home about 100 miles and the power steering pump leaked like a sieve.
Got the pump removed yesterday with a NAPA replacement in hand. When disconnecting the old pump i noticed there was no high pressure fitting on the pump to connect the hose and pump. Is there supposed to be? I think i saw one mentioned in the shop manual, and there is a reference to one on a tag with the new pump.
Do i just connect the hose directly to the pump, or is there a fitting I’m missing?
Thoughts?
Offline JohnnyPopper
  • Old Goof
Re: Power steering pump/high pressure hose
« Reply #1 on: January 24, 2021, 02:07:32 pm »
If you got the right replacement you should have all the parts you need.
Not able to picture what you think you're missing; Can you post a pic?
If you're talking about the large nut that the High pressure hose is tied down to, you can remove it from your old one and reused, make sure you have a good O-ring or get a new one.
1980 C-10 under construction
Offline GMJager
« Reply #2 on: January 25, 2021, 03:42:03 pm »
Johnny thanks for the reply... I actually was missing a piece - that large nut/nozzle with the o-ring. NAPA replaced it after I called and took it in to them today! New pump is now in, and works beautifully!
  • Old Goof
« Reply #3 on: January 25, 2021, 05:09:34 pm »
Glad it worked out!
And thanks for letting us know...sometimes we're left wondering if some things ever get fixed  ::)
