Author Topic: ported vacuum switch  (Read 4312 times)
Offline dirtracer
« on: January 01, 2007, 02:56:00 pm »
I have broken the plastic top part off the pvs in the thermostat housing and a new one has to be ordered.Ive got all the vacuum lines plugged that connected to it and it seems to be running fine.My question is since its mounted in the thermostat housing will any water come out since the plastic top part is gone.   thx
Offline DnStClr
Re: ported vacuum switch
« Reply #1 on: January 01, 2007, 03:50:00 pm »
No. The T doesn't port into the thermostat.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: January 01, 2007, 06:45:00 pm »
If you keep the tvs switch in place, it wont leak.  It is threaded into the thermostadt housing, but it is solid....the bottom doest actually open up.  It simply a copper part that is sensitive to heat.  Once it is hot enought it allows vacuum to circulate through the lines.  Antifreeze doesnt circulate through the vacuum lines.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
