Author Topic: Clutch  (Read 3037 times)
Offline chevykid
Clutch
« on: March 01, 2021, 08:33:17 pm »
Hey guys, I've got a 74 chevy k10 with a small block 350 and an sm465. The problem I'm having I believe is in the clutch. When I push the clutch in, no problem, but when I release the clutch it makes a grinding noise. I replaced the clutch and transmission and this is the first time I've started it since I replaced it. Any ideas what it is? Thanks.
Re: Clutch
« Reply #1 on: March 02, 2021, 10:29:21 am »
Check the oil level in the trans.  Did you replace the pilot bearing and verify that it was the correct one beforehand?  Possibly a bad input shaft bearing(?).  It's tough to "imagine" the noise, let alone the source, without more information.  Post a soundbite.
Offline chevykid
Re: Clutch
« Reply #2 on: March 02, 2021, 03:26:59 pm »
I got a pilot bearing with the clutch I bought. Oreilys said it was the right one... I'm having trouble uploading the sound but it almost sounds like a grinding clutch like when you don't push it in all the way and try to shift, but less aggressive.
