Author Topic: 84 C10 Tilt Column Shift Collar  (Read 8685 times)
Offline Ronno6
  • Elder Student
« on: March 08, 2021, 11:06:10 am »
I am swapping a tilt column into my 84 C10.
The column was originally auto shift.
I have installed a Muncie 4 speed.
Can I replace the shift collar with one for a floor shift setup"
You can lead a man to water, but yoiu can't keep him from pissing in it.
Offline JohnnyPopper
  • Old Goof
Re: 84 C10 Tilt Column Shift Collar
« Reply #1 on: March 08, 2021, 02:19:57 pm »
I'm sure that floor shifting trucks came with a plain shifting collar, just need to find one.
1980 C-10 under construction
« Reply #2 on: March 08, 2021, 03:19:00 pm »
The tilt column floor shift has a little lever you have to push down in order to turn the key in the lock/remove position.  Not sure if the collar is interchangeable.
