Author Topic: Squeaky Drum Brakes & A Terrible Mechanic.  (Read 113580 times)
Offline Spool
« Reply #150 on: April 08, 2021, 08:21:40 pm »
New update.
I ordered Dorman cylinders and they sent Wagner’s. They fit- almost... I needed to grind the top of it ever so much for clearance to fit.
Cleaned up the backing plate nicely too.
But noticed the bottom two landings have a nice little groove in them... Can I still get more life out of the backing plate?
 (Pics attached.)
« Last Edit: April 08, 2021, 08:23:22 pm by Spool »
Offline JohnnyPopper
  • Old Goof
Re: Squeaky Drum Brakes & A Terrible Mechanic.
« Reply #151 on: April 08, 2021, 08:52:01 pm »
I would run them  8)
1980 C-10 under construction
Online bd
« Reply #152 on: April 08, 2021, 08:58:49 pm »
...Check the shoe lands ... for deeply incised grooves and, if necessary, sand them just enough to remove any abrupt edges that may cause the shoes to catch.  Smear a dab of white lithium grease on each of the lands...
Offline Spool
« Reply #153 on: April 08, 2021, 09:22:04 pm »
Thanks guys.
Good to hear to still use them, as I just discovered the same on the drivers side.
Sanding them isn’t getting me very far, but they’re sanded for sure.
But they’re by no means flat.
Online bd
« Reply #154 on: April 08, 2021, 09:29:49 pm »
Use a sharp mill file if you have one followed by 80-grit paper.  A better method is to use a 60-grit sanding disc to touch it up.  Just make sure there are no lips that can trap the edge of the shoes.
Offline Spool
« Reply #155 on: April 08, 2021, 09:32:48 pm »
I suppose a metal grinder would be over kill...
I have a sander, but only 150 for it at the moment. I’ve been using coarse emery cloth at the moment.
  • Old Goof
« Reply #156 on: April 08, 2021, 09:39:27 pm »
I don't know, with a closer view, look like you might want to do something.
Well, per bd, you don't want them to catch, but it doesn't look like there are any burrs or ridges.
Couple of fixes: A: Weldy weld, grindy grind smooth. B: Braze and fill, grind smooth. C: JB weld, grind smooth.
Maybe B & definitely C would require removal of the plate so as to apply work to a flat surface.
In the grand scheme of thing, your brakes are going to ignore those grooves.
Offline Spool
« Reply #157 on: April 08, 2021, 09:48:11 pm »
Whoop whoop... lucked out and found these buried in my tools. Must be my fathers from years ago.
Online bd
« Reply #158 on: April 08, 2021, 10:10:11 pm »
That's a wood rasp.  Good luck using it on steel.
Offline Spool
« Reply #159 on: April 08, 2021, 10:11:55 pm »
I’m gonna be burning the midnight oil assembling the brakes- I’ll post pictures to confirm my assembly when I’m done.
Yet, one last question for the evening:
In the picture, from bottom to top- outer lock nut, ‘tab lock’, inner lock nut, and.... what is the forth piece?
I only had one on the drivers side, not the passenger side. Is it essential?
So, after I finish assembling these brakes, bleeding the brakes and posting final pictures to confirm, I'll be looking to get the drum on for adjustment, before the tire.
Question still remains... This forth piece I have for the drivers side, do I need one for the passengers side? If so, this is gonna put me another two days behind schedule.
« Last Edit: April 09, 2021, 03:47:16 pm by Spool »
Offline Spool
« Reply #160 on: April 08, 2021, 10:12:54 pm »
Haha- believe it or not, it did the trick.
There’s a groove, but less of one with no significant lip!
  • Old Goof
« Reply #161 on: April 08, 2021, 10:14:12 pm »
Be aware that filing them smooth lowers the plane the other lands are on. In other words, the shoes will not touch those lands.
Better to fill and grind smooth or just leave them alone.
I would run them...
Offline Spool
« Reply #162 on: April 08, 2021, 10:18:45 pm »
White lithium grease
  • Old Goof
« Reply #163 on: April 08, 2021, 10:23:34 pm »
It's a keyed spacer between the bearing and the first adjusting nut. Originally came one for each side. sorry... ::)
You can pry get away without it, but...
Offline Spool
« Reply #164 on: April 08, 2021, 10:41:33 pm »
It doesn’t fit snuggly against the bearing though- it floats around.
I missed it when I originally disassembled everything, and then it fell out of the drum a day later when I flipped it over.
So, you’re saying I need another one?
Don’t happen to know the part number do you?
