Author Topic: Trans Swap  (Read 4716 times)
Offline 77GMCSerria
Trans Swap
« on: January 01, 2007, 01:14:00 am »
Is it possable to switch from a 3 speed manual on the tree to a 4 speed manual on the tree?
Offline 77GMCSerria
Re: Trans Swap
« Reply #1 on: January 01, 2007, 02:09:00 pm »
I am looking at a 1972 chevy C10 w/ a 307 and 3 on the tree. I was thinking about changing the motor to a 454 but I would have to change the trans to a 4 or 5 speed and was woundering if I could use the shifter on the tree for a 4 or 5 speed?
Edited by: 77GMCSerria at: 1/1/07 8:45 pm
Offline DnStClr
Re: Trans Swap
« Reply #2 on: January 01, 2007, 03:45:00 pm »
They're floor shifters- Saginaw, Muncie.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline 77GMCSerria
Re: Trans Swap
« Reply #3 on: January 01, 2007, 08:41:00 pm »
So bassically if I use a saginaw or Muncie I can use the column shifter?
Thanks
Edited by: 77GMCSerria at: 1/1/07 10:11 pm
Offline roundedline
Re: Trans Swap
« Reply #4 on: January 02, 2007, 04:55:00 pm »
You can't use the column shifter for anything but a 3 speed, unless you plan to re-engineer it for the other lever....
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
