Author Topic: AC Compressor cycling  (Read 10427 times)
Offline jsc
« on: March 19, 2021, 05:21:43 am »
Hi!  I've got an '83 C10, which just came out of the shop after having some carb and exhaust issues.  But now my AC compressor is "cycling" on regular intervals, about every 5 seconds.  I can hear it click from inside the cab, and I can watch it cycle on and off when I'm under the hood.  AC is not blowing cold, even though it was before it went into the shop.
Any thoughts?  It always frustrates me when I put a vehicle in the shop, only to find a new problem when I get it out.....
Thanks,
John
Online Rapid Roy
  • Euless, Texas
Re: AC Compressor cycling
« Reply #1 on: March 19, 2021, 06:19:18 am »
Usually low on freon.
Mopar by Birth
Chevy by Choice
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: March 22, 2021, 10:17:46 pm »
The Rapid One is correct...
Was your AC solid before? Had you serviced it recently?
Do you regularly use this shop?
I know I , too many questions but you/we need to start somewhere before making aSSumptions.
1980 C-10 under construction
Offline Mike81K10
« Reply #3 on: March 22, 2021, 11:06:18 pm »
Don't use your A/C until it is serviced. Being low on freon can damage the compressor. If you have a leak, you can lose oil as well. Try to see if you can find a leak.
« Last Edit: March 22, 2021, 11:10:06 pm by Mike81K10 »
  • Old Goof
« Reply #4 on: March 22, 2021, 11:16:42 pm »
Good call by Mike.
Look for oil leaks around the tubing/fittings, not hard to spot.
Offline jsc
« Reply #5 on: March 25, 2021, 05:22:45 am »
Thanks.  Yes, I've used the shop before.  And yes, it was running correctly before I put it in for service.  It's sat in my garage since, so I haven't run it.
I guess I was wondering if it could be electrical at all.  Squarebodies usually have some demons electrically,
  • Old Goof
« Reply #6 on: March 25, 2021, 11:21:23 am »
One good thing the factory did was install a pressure sensor, that when too low, will not allow 12v to go to the compressor magnetic clutch.
Could just be coincidence that the gas went low after the visit. You can buy refrigerant with a pressure gauge and tell right away. If you're in Cali (too bad for us) the can will cost you a refundable 10.00 when you bring it back (Within 30 days!)
Offline jsc
« Reply #7 on: March 25, 2021, 08:41:27 pm »
Thanks.  I'm feeling better about it all
  • Old Goof
« Reply #8 on: April 29, 2021, 10:37:08 pm »
So what ever happened?    ???
