Author Topic: Dual tank switch kills the engine  (Read 7152 times)
Offline shinkle
« on: April 10, 2021, 11:24:14 am »
I have an 87 R10 dual tank.  The driver side tank and gauge works great.  When I flip the tank switch to the passenger side the engine instantly dies.  I replaced the switch and put gas in the passenger tank.
Any suggestions?
1987 R10 5.7L TBI
Offline MIKE S
  • Member
Re: Dual tank switch kills the engine
« Reply #1 on: April 10, 2021, 01:21:16 pm »
More than likely the in tank fuel pump in the passenger tank is bad.
« Reply #2 on: April 10, 2021, 01:26:23 pm »
Do you hear the tank selector valve located below the cab ratchet when you switch tanks?  Does the fuel gauge switch tanks?  The motorized valve may not be moving full rack to select the opposite tank.  Alternatives could be a faulty in-tank fuel pump, poor continuity somewhere between the dash switch and the fuel pump, or a faulty fuel pump ground.
Fuel System Schematics (and fuel gauge troubleshooting)
Offline shinkle
« Reply #3 on: April 11, 2021, 02:49:13 pm »
If I flip the switch to the passenger side and turn the ignition key, I don't hear a click and whrrr sound.  If I try it on the good driver side I definetly hear the click and whrrrrr.  The gauge does not work on the bad passenger side.
1987 R10 5.7L TBI
« Reply #4 on: April 11, 2021, 03:59:09 pm »
There is a 3" long red pigtail terminated by a black insulator hanging freely from the fuel pump relay located at the top of the engine compartment firewall on the passenger side of center.  Connect a 20-amp fuse-protected jumper between the free end of the pigtail and the firewall junction block stud (B+) located nearby on the firewall above the driver-side valve cover.  With the ignition switched OFF and the passenger fuel tank selected, do you hear the fuel pump running in the passenger side tank?
Offline All_American_C10s
« Reply #5 on: April 14, 2021, 05:25:30 pm »
I bet you're right.  I had the exact same issue.  Ended up replacing the in-tank fuel pump on the bad side.
Sent from my SM-G977U using Tapatalk
Shane Free
'87 5.7L Silverado every day driver
'67 C10 currently in restoration
