Author Topic: Bad sound distortion on stock stereo  (Read 10142 times)
Offline shinkle
« on: April 10, 2021, 11:27:00 am »
My stock radio has a digital clock with cassett player. It works great except for a bad distortion on the left side speakers. Mainly the rear speaker on the bass sound. The beat beat beat rythm of songs is badly distorted. I replaced the rear stock speakers with no luck. It does it on both antenna and cassette tapes.
Any suggestions?
1987 R10 5.7L TBI
Re: Bad sound distortion on stock stereo
« Reply #1 on: April 10, 2021, 12:48:49 pm »
Try thoroughly cleaning and verifying all of the connections between the head unit and the speakers.  Validate the ground connection for the head unit.
Offline mdws1987
« Reply #2 on: April 10, 2021, 04:21:27 pm »
Try reversing the left and right connections at the radio. If the distortion moves to the other side, the radio output may be bad...
Offline shinkle
« Reply #3 on: April 10, 2021, 10:12:24 pm »
Where would the ground for the head unit be located?
I'll try the left right swap and see if the distortion follows it
1987 R10 5.7L TBI
« Reply #4 on: April 10, 2021, 11:18:52 pm »
If it follows the factory location, the radio grounds to the left kick panel area or the e-brake pedal frame.  Switching the left rear and right rear feeds is a good idea.
Offline calif phil
« Reply #5 on: October 16, 2021, 08:38:49 pm »
I sprayed the shafts of my stock ETR radio with Deoxit and it improved the sound immediately.   I took the radio out to do it.
Offline JohnnyPopper
  • Old Goof
« Reply #6 on: October 16, 2021, 09:33:37 pm »
That stuff is phenomenal! D5 for general purposes, F5 made the same but is good on faders.
(funny- spell check doesn't recognize "fader") ::)
Please post what you find!
1980 C-10 under construction
« Reply #7 on: October 16, 2021, 11:34:00 pm »
First name "garth," from a galaxy... well, somewhere...  :)
