Author Topic: Under hood spray paint  (Read 3439 times)
Offline MY1978
  • Just a girl and her truck since 1978
« on: April 18, 2021, 07:13:48 am »
I need to repaint my air filter housing and I want to paint my master cylinder.  I may also touch up radiator and engine bay wheel wells.  I want to use a flat black and was wondering about any suggestions for the paint.  Will high heat Rustoleum primer and paint be a good choice?  This is not a show truck, this my driver a few times a week, during nice weather, so do not need any fancy ceramic, high priced, shiny paint.
Thanks
« Last Edit: April 18, 2021, 07:17:30 am by MY1978 »
Offline JohnnyPopper
  • Old Goof
Re: Under hood spray paint
« Reply #1 on: April 18, 2021, 05:40:42 pm »
That's a good choice. They also make a satin finish, not shiny but not flat. Subtle.
Make sure you clean surfaces thoroughly, I use brake cleaner on bare metal prior to shooting.
Painters tip: use a blow dryer to gently heat the paint can. Two benefits: paint flows easily, and pressure increases slightly inside the can, causing a finer spray.
I also preheat the surface that I'm painting the same way for the same results.
Post some before and after pics!
1980 C-10 under construction
Offline MY1978
« Reply #2 on: April 18, 2021, 07:34:11 pm »
Thanks and will be sure to post pics.
