Author Topic: quadrajet secondaries  (Read 5010 times)
Offline usmcchevy
« on: January 01, 2007, 10:18:00 am »
i rebuild a quadrajet carb and it seems like the secondaries arent opening up like they did before i rebuilt it. what could the problem be. there is spring tension on the upper butterfly and i converted it to manual choke .
Offline 75 C20
Re: quadrajet secondaries
« Reply #1 on: January 04, 2007, 07:49:00 pm »
u could give this book a shot
or this ones cheaper- same book http://www.themotorbookstore.com/howtoreandmo1.html one of the chapters is just about Quadrajet secondary metering rods
sounds like wut u need
Edited by: 75 C20 at: 1/4/07 7:55 pm
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline TRUCK6DRIVER
« Reply #2 on: January 04, 2007, 09:40:00 pm »
The secondaries air butterflies ( the top ones )have a spring adjustment where the lockout rod connecte to them. You can adjust them to get the feel you want. Adjust is very small amounts because the spring is sensitive and too much and you will have a time getting them back to where they were. All you need is an allen wrench and a small flathead screwdriver to do this.
Also check to see if the secondary lock out rod is able to move freely. This cound be a problem area since you converted it to a manual choke. When the choke is on the secondaries are locked out with a pin attached to the secondary butter flies. You can cut this off i you do not want the lock out to work.
