Author Topic: Rough running 350  (Read 8621 times)
Offline krigermoose
  • 1986 GMC C1500 5.7L
Re: Rough running 350
« Reply #15 on: May 09, 2021, 05:07:09 pm »
I did replace the distributor. You may be right about that, I'll look into it.
And sorry, I worded it weird with the ignition coil. I just got a new one at one point because I thought the original one was bad and just kept the old one. They're the same, I was just trying whatever I could to eliminate variables.
Offline TexasRed
« Reply #16 on: May 09, 2021, 07:36:41 pm »
If you're reading the right degrees of advance, then the distributor should be correctly installed. It usually gives problems where you can't advance or retard around top dead centre.
I was asking more if the coil was a stock style or the "high performance" coil. I'm not a big fan of the high performance (output) ones.
Why did you replace the distributor? Were you getting this problem before the swap?
« Last Edit: May 09, 2021, 07:41:35 pm by TexasRed »
Offline krigermoose
« Reply #17 on: May 12, 2021, 01:31:38 am »
I do have a stock coil and distributor I just got from Napa. Admittedly I originally replaced it when I didn't know what I was doing about a year ago, maybe longer. I can't even remember the exact reason.
Keep in mind this has been a very very slow project and I was working on everything else on the truck until now...
But before the swap it ran terribly for other reasons so I wouldn't have been able to tell. I'm probably going to pull it anyway and drop it back properly so I'm 100% sure it's not the problem.
Offline TexasRed
« Reply #18 on: May 12, 2021, 11:15:00 am »
Before you try the new distributor, I'd make sure your grounds are good. A lot of these trucks use the alternator bracket to attach the cable to the negative battery terminal. It can cause issues. I think I smoked an ignition box and a module in short order because of it. Both the box and the module were grounded separately to the battery and it still did it.
There's a decent write up by bd http://forum.73-87chevytrucks.com/smforum/index.php?topic=35756.0
Offline krigermoose
« Reply #19 on: May 12, 2021, 03:11:35 pm »
Thank you, I will do that. And sorry to clarify again when I referred to the "new" distributor I was talking about the one I put in a year ago.
